DP crash when duration resizing MIDI in Seq. Editor
mwilloam
Post by mwilloam »
https://www.youtube.com/watch?v=13BdlbB ... e=youtu.be
Macbook Pro 15" latest, 10.11.2, DP 9.01, 828mk3 hybrid, very minimal fresh install of everything. Anyone else notice this?
ccjones87
Re: DP crash when duration resizing MIDI in Seq. Editor
Post by ccjones87 »
I've had the same issue. Only solution I've found is to edit MIDI in the MIDI editor. I do prefer the sequence editor though...
DP 9.5 OSX 10.10.5 Late 2011 Apple iMac 3.4 GHz Intel Core i7, 32GB memory 1333MHz DDR3
mwilloam
Post by mwilloam »
Oddly, this stopped happening. It just appeared in a new project with a fresh install of 9.01 and I thought I just hadn't noticed it yet. It has not reoccured with several hours of editing. If it happens again I'll try to reproduce.
Not happening here. Could have been a corrupt file. If you go back to the file you were using before, does it happen again?
mwilloam
Post by mwilloam »
Shooshie wrote:Not happening here. Could have been a corrupt file. If you go back to the file you were using before, does it happen again?
Perhaps yeah. I can't even remember which file it was. I know it was a brand new file with the issue happening within a few minutes of using it. If it rears its head again I'll note any reproducible parameters.
james.sizemore
Post by james.sizemore »
I'm encountering this issue as well in DP9.01, using VEP to host my VIs. I would love a solution too!
