Automation on MIDI plugin
massimosammi
Post by massimosammi »
Hello,
I'm trying to write automation on a MIDI plugin (Echo) and I'd like the plugin to be in "bypass off" on bar 1 and on "bypass on" on bar 50.
I tried to look in the sequence window but I can't insert it, I also tried to to go to the channel strip, enabling automation record, and option clicking on the plugin while playing the sequence, but it didn't record it.
Any idea about what I might be doing wrong or how could I do it?
Tritonemusic
Re: Automation on MIDI plugin
Post by Tritonemusic »
Unfortunately, it can't be done in DP.
DP 10.13, OS 13.7.5, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
reedster
Post by reedster »
you could duplicate the track, put the plug on the duplicate track and use Track Mute/Unmute to control when you hear the effect.
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
I haven't tried MIDI learn, but its button appears on MIDI plugin GUIs. Perhaps you can assign an unused CC to the Bypass button and then automate with that controller.
massimosammi
Thanks a lot I'll try both solutions, they both sound really good.
Tritonemusic
Yes, both great suggestions. I guess I was just replying literally; as far as automating MIDI plugins are concerned.
