DP9 now shipping.
FutureLegends
Re: DP9 now shipping.
Post by FutureLegends »
musicman691 wrote:Has DP9 shown in anybody's registered products in their account yet? According to an email I got from Magic Dave he said to check back in 24 hours. But you know sometimes things work out faster than expected.
Looking now, my DP8 update was never added to "My Registrations"! Which I got from the swedish distributor. Can't remember, but I think I emailed MOTU about it at the time. I hope I still have the reciept! :shock:
Steve Steele
Post by Steve Steele »
jlaudon wrote:Sure. For example, I load an instance of Kontakt with 5 MIDI channels, and then want to change the MIDI channel of any of those 5 channels, say MIDI channel 5 to channel 10, there is no response, no pull down menu at all.
So you have 5 MIDI tracks in DP pointing to an instance of Kontakt with five instrument loaded in, each with it's own MIDI channel. You can't change the sending MIDI channel in DP, or the receiving MIDI channel in Kontakt?
cleamon wrote:Functionally ok with everything I've tried BUT personally, I hate the dark buttons with black text used in all the dialog windows. At least with the theme I have been using (Savannah). Why did they change an existing theme? In DP8 they are light grey with with black text -- much easier to read.
Guess I'll have to learn how to edit that.
Maybe because it makes it easier to see that a dialog box is inactive (e.g. if nothing has been selected for edit). The greyed out text in the action boxes looks inactive when it is against the slightly lighter grey of the background. But as you say, it ought to be easy to find and edit the background images to a light shade.
Killahurts
Post by Killahurts »
Darn.. I went to check out and got the "processing credit card" perpetual spinning wheel of potential and even likely failure. I don't know if they charged me or not.. :wink:
tshaps
Post by tshaps »
nightwatch wrote: But wait... are MIDI CC lanes only available in the Sequence window? Not in the MIDI window? This can't be. Ok, calm down. Read manual...
It was confirmed to me that the MIDI CC lanes are ONLY in the Sequence Window, not the MIDI Window, which is a massive disappointment. That said, apparently there is now a way to use key commands to switch between MIDI Controllers in the MIDI Window. Not as good, but a minor consolation.
cleamon
Post by cleamon »
I don't think it makes anything easier to see. For example in version 8 Savannah we had:
Pretty obvious what's enabled/disabled.
Same theme in version 9 it's
Still easy to tell, but everything is harder to read.
I know I can go in a edit all those (as my wife would say) wiggle digits, but I'd rather be making music.
Chuck
iMac (Retina 4K, 21.5-inch, 2017)|| 16GB Ram || OS/X 10.14.6 || Motu 828MkII || Steinberg UR242 || DP8.07
Macbook Pro (Retina, 13-inch), 2.7 GHz i5, 8GB Ram
Killahurts wrote:Darn.. I went to check out and got the "processing credit card" perpetual spinning wheel of potential and even likely failure. I don't know if they charged me or not.. :wink:
Same here. I thought I'd wait a few days and see if a receipt is emailed.
Sort of looks like it was standardized across themes. As for editing, I expect there is one background that needs to done. Or wait and see if Andy comes up with something.
primeevolutionary
Post by primeevolutionary »
I just bought my upgrade and received the confirmation and it's immediately showing up with the new activation code in My Registrations.
Macmini9,1 (M1, 2020) 16 GB RAM
MacBookPro15,1 2.6 GHz 6-Core (Intel, 2018) 16 GB RAM
OS X 14.7
DP11.32
2 896 mk3 192 kHz Hybrid FW • USB2
Stage-B16
2 828 mk1s
MTPAV USB
cleamon
Post by cleamon »
bayswater wrote:
cleamon wrote:
bayswater wrote:Maybe because it makes it easier to see that a dialog box is inactive (e.g. if nothing has been selected for edit). The greyed out text in the action boxes looks inactive when it is against the slightly lighter grey of the background. But as you say, it ought to be easy to find and edit the background images to a light shade.
Many, but not all. In fact there are some that use a dark background color, but not nearly as dark as this one.
[update]
I renamed the theme bundle, restore the original from time machine, edit the plist to include version 9. Both versions use the dark background. Mmm, hardcoded?
[updated update]
Got it. Apparently, if certain files (.png) are missing, DP9 uses a default different from DP8.
Chuck
Robert Randolph
Post by Robert Randolph »
Changelog of smaller things added in dp9!
https://www.gearslutz.com/board/11142081-post121.html
cleamon
Post by cleamon »
mikehalloran wrote:I was going to order from Sweetwater by clicking through the link. I am not seeing the boxed option, however. I have emailed them to see if it's available.
I talked to "my" salesman at sweetwater and he says
"I will have MOTU ship you a DVD and a physical manual after you order. That is no problem."
Even if it's an extra charge, I'll buy through them in order to support the forum.
Just got this:
nope, no charge for the Manual. $195 for the upgrade and once you register, they will send you the manual and DVD
But I'm pretty sure motu will want shipping on that.
Chuck
Interesting, the email I got from my Sweetwater rep says electronic delivery only.
I'll deal with it when I have some time -- fortunately, I have a few weeks. I think I need to make a phone call.
kgdrum
Post by kgdrum »
OK! Upgraded & installed,so far the jump to DP9 seems to be incredibly smooth and painless.
Congratulations to MOTU, DP9 looks like a great version! btw this doesn't feel like a .0 release
It might be trivial but I also love the new DP9 icon it has a great look and nice colors.
:love:
primeevolutionary
kgdrum wrote:btw this doesn't feel like a .0 release
It sure doesn't. I'm recording a new project that I started on 8.07 and I just installed 9 on my desktop and laptop and I'm going back and forth between the two seamlessly and with no noticeable detriments from the switch.
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
