VIENNA SYMPONIC LIBRARY?????
JAYEBEATS
Post by JAYEBEATS »
DOES ANYBODY NO IF U CAN IMPORT THE VIENNA SYMPONIC LIBRARY PATCHES INTO MACH FIVE??????????
IF SO PLEASE TELL ME
markbnyc
Post by markbnyc »
I have imported the VSL Opus 1 library just fine. Keep in mind, though that the legato performance files will be useless to you. You need the legato performance tool which is not available for Mach5. Other than that the actual sounds translate fairly well, imo.
Don't know about the regular (larger) VSL libs.
The new VI version of the Orchestral Cube has it's own player so you don't need M5 for that.
JAYEBEATS
Post by JAYEBEATS »
ACTUALLY I HAVE THE BIG BUNDLE AND I WOULD LIKE TO USE IT IN MACH FIVE...BUT I DONT WANNA IMPORT EVERY SOUND IT WOULD TAKE YEARS...SO I WOULD LIKE 2 IMPORT THE PATCHES THAT I COMES WITH
iMAS
Post by iMAS »
Don't get the samples....VSL has a new sample player !!! It's called the Symphonic Cube...go to there website and check it out. It just came out this pass saturday. I think this will be much better the EW platinum strings.
BradLyons
Post by BradLyons »
I've not imported into MachFive as I'm using it on a dedicated GigaStudio machine, but I would advise to buy the KONTAKT version.... I can't remember if it is both in the box or not.
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Spikey Horse
Post by Spikey Horse »
JAYEBEATS wrote:ACTUALLY I HAVE THE BIG BUNDLE AND I WOULD LIKE TO USE IT IN MACH FIVE...BUT I DONT WANNA IMPORT EVERY SOUND IT WOULD TAKE YEARS...SO I WOULD LIKE 2 IMPORT THE PATCHES THAT I COMES WITH
For VSL it's best best to use it in the original sampler format. What format is it in anyway? You know VSL allow you to 'sidegrade' to another supported format fairly cheaply in which case for DP I would suggest Kontakt 2.
Maybe that is the format you have anyway? It's good because by using K2 format (with K2 scripting) you can sidestep the need to use VSL's performance tool software which is of course necessary to play all the VSL performance patches. And K2 works great with DP.
M5 is not a supported format (nor ever will be now that 'VSL instruments' has been released) and you will end up with a lot of very weird sounding patches I'm afraid.
BTW it's seems a bit odd to buy the 'big bundle' (presumably you mean Horizon Series or Pro Edition) for use in an unsupported sampler?
Anyway I'll leave it at that :wink:
Kubi
Post by Kubi »
Spikey Horse wrote: BTW it's seems a bit odd to buy the 'big bundle' (presumably you mean Horizon Series or Pro Edition) for use in an unsupported sampler?
No kidding... I certainly could be wrong, but what's that smell?
