Mac Pro 4,1 running 10.9.5 DP 8.07 in 64 bit. Before anyone asks- I have the latest versions of EVERYTHING. This a clean fresh install from the ground up on a new SSD- the only things I've imported/migrated are my email and web links. I've been working for weeks on this install and everything is wonderful except Slate VBC quickly crashed a really simple project. This is the only crash I've had. Slate FG/X won't run at all as it's still 32 bit (that's a whole 'other thread). Maybe this a fluke or bad install, but if VBC is wonky I'll use other tools as my whole goal with this install is stability.
Is anyone running Slate VBC with DP 8 with no problems?
is Slate VBC working with DP8 for you?
- philbrown
Re: is Slate VBC working with DP8 for you?
VBC working fine here in 8.07. I'm still on Mountain Lion, though.
Did you try removing the VBC component from your components folder and then re-installing VBC? That might help.
http://www.davepolich.com
Hi--
The 'MU' unit didn't pass AU test first time round, so I had to re-install it and then the whole thing passed. VBC occasionally causes crash, especially when I'm switching from one unit to the other, I'd say it's 95% stable, but I still make sure I save the project before I load VBC/switch units within it.
FG-X works via 32 Lives in 64bit systems, some say it sounds different when used this way, I haven't A_B'd it to verify if it's true...
I'd say maybe try re-installing VBC and see if the situation improves.
Taka
OS 10.10.1, 16GB RAM, DP 8.07, Mac mini Server Mid 2011
Taka
DP11.3, OS 13.6.3, Mac Mini 2018 6 core 3.2GHz i7 32GB RAM
Slate, Waves, Soundtoys, GRM Tools, Audio Ease etc etc..
- philbrown
Thanks for the replies.
I'll try reinstalling it and see what happens.
I'm having the same problem in a similar setup - Trashcan with 10.9.5, DP 8, and Slate VBC making things freeze up or crash as well. The Virtual Tape Machine is not a problem; it's specifically the VBC plugins. Did the reinstall work for you?
