Any way to modify fader scale/resolution?
MDesigner
Post by MDesigner »
Say I'm dealing with some really loud virtual instruments that I want to automate. I've got one now that is already fairly loud at -22dBFS, so when I automate it, I'm in this window of infinity to -25dBFS or so, which of course is miniscule. Is there some way to change the fader scale so I can have a wider stretch to drag between dead quiet and -25dBFS?
Sam Hulick
Composer
http://samhulick.com
Social Media: [ Twitter | Facebook ]
Re: Any way to modify fader scale/resolution?
Post by Shooshie »
I think it's the shift key or option key; I forget which, enables you to move the fader at decimal-point range.
MDesigner
Post by MDesigner »
Aha! I don't know why I didn't think of it. It's the command key. Thanks! I was asking more about visually scaling it, but this works too.
Sam Hulick
Composer
Phil O
Post by Phil O »
How about inserting a Trim plug, so your fader starts in a different position?
MDesigner
Post by MDesigner »
Good idea. Thanks!
Sam Hulick
Composer
philbrown
Post by philbrown »
Phil O wrote:How about inserting a Trim plug, so your fader starts in a different position?
You could also lower the bite gain (or bite volume) and achieve the same thing. There is usually more than way to accomplish something in DP!
MDesigner
Post by MDesigner »
It appears bite gain/volume is for soundbites. This is an instrument track, so maybe Trim is the better route. The Cmd-drag works on the fader, but it moves almost too slowly to automate the way I want.
Sam Hulick
Composer
philbrown
Post by philbrown »
MDesigner wrote:It appears bite gain/volume is for soundbites. This is an instrument track, so maybe Trim is the better rout
You're right. I was thinking about how I use it- in a different situation. Trim is what you want.
I don't suppose your VI has a master volume knob in there somewhere? Seems like most of mine do.
You could drop the volume within the VI's GUI, then scale back up your automation. (Or am I missing something?)
MDesigner
Post by MDesigner »
Yeah, I did think of that, but it would make those few patches way quieter than the rest of the factory presets.. so if I switch between them, I'm likely to blow my ears off. ;) (volume is per-preset, not global on the VI)
Another option I could go with is to slap a Trim plugin on the track, drop the gain there to a comfortable level (with the fader at 0dBFS), and then I could use the fader which is slightly more accessible than the Trim plugin.
Sam Hulick
Composer
