A couple of problems related to BDE? DP 4.52 HELP PLEASE
amerecordingstudio
Post by amerecordingstudio »
Hi, recently i've been experimenting with DP's BDE on my drum tracks (8 tracks/take), and i've found that the only way i can get it to sound good enough (no phasing in the overheads) is to create soundbits from beats (using the kick drum and the snare drum tracks) and then quantizing the soundbites, dragging all of the left edges to the left (to cover gaps) and then crossfading the soundbites together.
The two prblems i've run into are these:
a) the crossfading takes about 2 hours to complete
b) DP will play the tracks only for a few bars before tracks start getting out of sync or stop playing all together. To get around this, i've had to duplicate the tracks (to avoid re-calculating the crossfades), merging, and copying the merges to a new take on the orginal tracks. Then i listen to the merge, find the areas where i need to adjust the crossfade boundries, adjust them, and then repeat the whole process.
I'm just wondering if anyone can give me a bit of insight into these issues.
James Wallace
P.S. I am running on a Dual G5 2Ghz with 1.25gb of ram, and a M-audio FW-410.
Last edited by amerecordingstudio on Wed Nov 23, 2005 9:19 am, edited 1 time in total.
amerecordingstudio
Anyone?
Dual G5 2.0Ghz 1.25Gb running DP4.52 in OSX 10.4.2 with M-Audio FW410
Dual G5 1.8Ghz 1.5Gb running DP4.52 in OSX 10.3.9 with MOTU 2408 MkIII
amerecordingstudio
please? somebody must have an idea of what i can do, or at least let me know ththis is the way i'm going to have to work.
