Vienna instrument problem
jim2b
Post by jim2b »
Hi Folks,
I use Vienna Instruments "Special Edition" woodwinds.
I can close DP(8.05), but the computer hangs on shutdown. It says that the VSL server is still open,
but I can't do anything because of the spinning beachball, and, I don't know what they are talking about.
Please help.
Thanks in advance,
Jim
DP 11, High Sierra, Mid 2010 Mac Pro 3.33ghz, 32gb Ram
Timeline
Re: Vienna instrument problem
Post by Timeline »
Not having that issue here but latest drivers are loaded
leigh
Post by leigh »
Have you tried quitting DP before closing the VSL server?
**Leigh
Timeline
Post by Timeline »
I posted another BTD issue with VI's. I have changed my position on BTD. DP8 IS broken where VI's are concerned confirmed. Rendering is the only way.
Kontakt 5 main culprit.
jim2b
Post by jim2b »
Hi folks,
I'm still confused. I use Vienna Instruments SpecialEdition wood winds as a VI.
No slaves. I also use Kontakt, Spectasonics products, etc.
I close the sequence and quit DP and all is well. When I go to shut down my Mac, it hangs.
There is a message that the VSL server has to be shut down, but since there is a spinning beachball,
I can't do anything. There must be something about Vienna Instruments that I don't understand.
Thanks again for your help.
Jim
Timeline wrote:I posted another BTD issue with VI's. I have changed my position on BTD. DP8 IS broken where VI's are concerned confirmed. Rendering is the only way..
So you keep saying - but posting this over and over doesn't make it so - unless it is. One of the recent DP 8 updates fixed B2D issues for many.
I haven't had a problem except twice (once on my Beige G3 n DP 2 and again on my G5 in DP 5). Both times it turned out to be bad RAM and OWC's warranty fixed me right up. Apparently, B2D is an excellent 'canary in the coal mine' for defective memory as I have found out.
So, have you actually confirmed your B2D issues with MOTU tech support? I have found that they are very up-front when something doesn't work as it is supposed to. What do they say?
If it is a real issue we'd all like to know.
Timeline
Post by Timeline »
Mike, I have nothing but respect for your opinion. If this is an issue with my DP 8.06 then what can I look for in the system files that possibly did not receive the update? I have done permissions many times and admit to having OS10.9 issues for instance my mail is currently broken and I can't save the signature file changes so maybe it is me. I will keep an open mind that it is for now. What next?
