Can anyone confirm this? With "update edit windows to play enabled chunk" on, QS does not update when he active chunk is changed. I must do it manually. Thanks.
Frank Ferrucci
DP8.06 Quickscribe not updating to Play Enabled chunk
Frank Ferrucci
http://www.ferruccimusic.com
Re: DP8.06 Quickscribe not updating to Play Enabled chunk
I think that only works for editors in the Consolidated Window. It is a CW preference. QS updates properly for in 8.06 if it is in the CW, but not if it is in its own window.
I'll try with popped out graphic editor and see if it updates or not. A popped out Mixer window will still update, but then again it's not an edit window. Thanks.
Frank Ferrucci
Frank Ferrucci
Frank Ferrucci
