DP8.06 Quickscribe not updating to Play Enabled chunk
frankf
Post by frankf »
Can anyone confirm this? With "update edit windows to play enabled chunk" on, QS does not update when he active chunk is changed. I must do it manually. Thanks.
Frank Ferrucci
Frank Ferrucci
http://www.ferruccimusic.com
Re: DP8.06 Quickscribe not updating to Play Enabled chunk
I think that only works for editors in the Consolidated Window. It is a CW preference. QS updates properly for in 8.06 if it is in the CW, but not if it is in its own window.
frankf
Post by frankf »
I'll try with popped out graphic editor and see if it updates or not. A popped out Mixer window will still update, but then again it's not an edit window. Thanks.
Frank Ferrucci
Frank Ferrucci
