Automation - I hear it but don't see it?
mesayre
Post by mesayre »
Hi everybody,
I have a positively weird issue cropping up from time to time. I have some sessions where volume automation seems to be working correctly (everything sounds correct and I can hear the fades), I don't see the faders moving in the mixer. I have other sessions that appear to work fine. I've yet to detect a pattern here (I'm actually troubleshooting this for someone else). It's rather disconcerting. Anyone else seen this issue?
Already tried deleting the preferences files.
Would appreciate any advice you could offer.
Mike
DP 8.06
Mac 10.6.8
Faderport
DP 10 - Win 10 - Ultralite AVB
Re: Automation - I hear it but don't see it?
mesayre wrote:Hi everybody,
Mike
DP 8.06
Mac 10.6.8
Faderport
Are you sure you're using track automation, and not bite gain/volume?
mesayre
Post by mesayre »
Yeah, these are all MIDI tracks. Sorry, should've said that before.
Are you viewing the mixer for the current chunk?
mesayre
Post by mesayre »
Hi,
Yes, there's only one chunk in the project. Also, all the other tracks chase, it's just the track that's selected that doesn't chase. It's like DP thinks someone is touching the fader, even when no one is.
Mike
Might be time to call that Great Unicorn in the Sky (MOTU tech support). :unicorn:
FMiguelez
Post by FMiguelez »
mesayre wrote:Hi,
Mike
Are you sure the channel is not set to an automation mode in the mixer (e.g., Latch, touch)??
Make sure it's set to read it.
mesayre
Post by mesayre »
I think I tracked this down. Looks like a buggy Faderport firmware was causing some chaos with DP's HUI driver, leading to some seriously weird, unpredictable stuff. Upgrading the firmware to 1.3.8 seems to have fixed the issue...for now :)
Thanks everyone!
Mike
