In the MIDI editor, how does one grab the off velocity hits?? Or can you?? My hand tool only seems to grab the on hits...
Is there a way to grab the off velocities in the MIDI editor
Off Velocities in graphic editor
HI,
I ran into this one also.
I have an old version of DP (3.11) and in that one you can't grab the off velocities in the graphic editor. Instead you have to go under the Change Velocty command in the Region menu and you can select off veloctites instead on on velocities. So you'd make your selection of notes, go there and change the value for the off velocities.
According to the manual, you can see the off velocities in the graphic editor but that's about it.
I don't know if this helps, but it works in DP 3.11
