Is there a way to grab the off velocities in the MIDI editor
Hesseman
Post by Hesseman »
In the MIDI editor, how does one grab the off velocity hits?? Or can you?? My hand tool only seems to grab the on hits...
yofo
Post by yofo »
I think you can go to the graphic editor and switch the view filter to "off velocities" and then highlight them and then switch back to MIDI editor and then grab them. I hope thats right !
Mac OSX 10.6.8 2 x 2.66 GHz dual-core Intel Xeon 8GB 667 MHz DDR2 FB-DIMM RME Fireface 800
ClydeXP
Off Velocities in graphic editor
Post by ClydeXP »
HI,
I ran into this one also.
I have an old version of DP (3.11) and in that one you can't grab the off velocities in the graphic editor. Instead you have to go under the Change Velocty command in the Region menu and you can select off veloctites instead on on velocities. So you'd make your selection of notes, go there and change the value for the off velocities.
According to the manual, you can see the off velocities in the graphic editor but that's about it.
I don't know if this helps, but it works in DP 3.11
chrispick
Post by chrispick »
I'm pretty sure you can just grab them -- only they're hard to grab. If I remember correctly, I've adjusted them before by simply moving them.
blue
Post by blue »
You can't grab them, but you can edit them in the event list and in the event strip on the graphic editor. Select the notes first, then pop edit the numbers.
