Trashing a .dmg…
Schweats
Trashing a .dmg…
Post by Schweats »
I created a .dmg only to realize I didn't need it. There is nothing contained in the disk image.
I drag it to the trash and initiate the empty trash command and the progress bar travels about half way across
and hangs… It won't complete the empty trash routine. I check and double check to make sure there is nothing
contained ………… check !
Any clues ?
Many TIA
Schweats
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
Tritonemusic
Re: Trashing a .dmg…
Post by Tritonemusic »
Have you tried ejecting it using Disk Utility? Maybe that will do the trick.
Also a restart or log out and back in if the eject doesn't work. You might be able to simply eject it from the finder.
FMiguelez
Post by FMiguelez »
Are you the owner of the file?
I'd double check via command-I. Even if it is, try setting read/write privileges to yourself and do the "Apply to Enclosed items" command. Then try again.
Also, if your .dmg is not too large, you could try the "Empty Trash Securely " command, or even deleting the file via Applescript.
Sometimes quitting/restarting the "Finder" also helps.
billf
Post by billf »
The utility app Trash It will probably fix that for you. I've used it with success before on stuck files like the one you are describing.
http://www.nonamescriptware.com/trash-i ... available/
Reboot and see if there's a problem. Highly unlikely. Chances are that, whatever file you created it in is still active.
Schweats
Post by Schweats »
Thanks everyone……  the 'Trash-It' utility got it done !!
Schweats
Schweats
Thomas.B.
Post by Thomas.B. »
It's probably time to repair your permissions with DiskUtility to avoid further issues. I would also recommend OnyX to keep your file structures and system files in order. It's a highly regarded free utility made by the french developer. Opening and finishing a fine bottle of french wine whenever these issues appear is another attractive option. :mrgreen:
