Trashing a .dmg…
Trashing a .dmg…
I created a .dmg only to realize I didn't need it. There is nothing contained in the disk image.
I drag it to the trash and initiate the empty trash command and the progress bar travels about half way across
and hangs… It won't complete the empty trash routine. I check and double check to make sure there is nothing
contained ………… check !
Any clues ?
Many TIA
Schweats
Any clues ?
Many TIA
Schweats
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
- Tritonemusic
Re: Trashing a .dmg…
Have you tried ejecting it using Disk Utility? Maybe that will do the trick.
DP 10.13, OS 13.7.6, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
Also a restart or log out and back in if the eject doesn't work. You might be able to simply eject it from the finder.
- FMiguelez
Are you the owner of the file?
I'd double check via command-I. Even if it is, try setting read/write privileges to yourself and do the "Apply to Enclosed items" command. Then try again.
Also, if your .dmg is not too large, you could try the "Empty Trash Securely " command, or even deleting the file via Applescript.
Sometimes quitting/restarting the "Finder" also helps.
The utility app Trash It will probably fix that for you. I've used it with success before on stuck files like the one you are describing.
http://www.nonamescriptware.com/trash-i ... available/
Reboot and see if there's a problem. Highly unlikely. Chances are that, whatever file you created it in is still active.Also a restart or log out and back in if the eject doesn't work.
Thanks everyone…… the 'Trash-It' utility got it done !!
Schweats
Schweats
Schweats
It's probably time to repair your permissions with DiskUtility to avoid further issues. I would also recommend OnyX to keep your file structures and system files in order. It's a highly regarded free utility made by the french developer. Opening and finishing a fine bottle of french wine whenever these issues appear is another attractive option.
