Bouncing to disc in DP8
So is there no way to set an in out point for a bounce to disc except for selecting a items to be bounced in the track window? This can't be so can it?
Re: Bouncing to disc in DP8
Not sure what you mean? I usually designate a time range for a bounce. What other way would you do it?
If you do not set a range, BTD doesn't work as far as I have seen.
That's how I understand it. I usually save a selection range first so I can use it again. Then I select all and then load the selection range and do the bounce.mikehalloran wrote:If you do not set a range, BTD doesn't work as far as I have seen.
- daniel.sneed
I usually set a marker labelled *start*, and another *end*.
Clicking the first above conductor track will select everything in-between.
If any markers between them, just extend selection thru shift+click.
dAn Shakin' all over!
- Dan Worley
That's exactly the way I do it, too. I very much appreciate the Saved Times feature.James Steele wrote:
... I usually save a selection range first so I can use it again. Then I select all and then load the selection range and do the bounce.
DP10.13
- Shooshie
Same here with the markers. Because it's a delicate thing to get the exact points where I want to stop and start, I set markers. Then I select the tracks. This makes it easy to revisit the sequence and BTD again and again.daniel.sneed wrote:I usually set a marker labelled *start*, and another *end*.
- daniel.sneed
Funny! I'm never happy with first bounces, too.Shooshie wrote:[...]revisit the sequence and BTD again and again.
Will always do many. Sort of superstition sometimes...
