DP 7 Hangs On Startup - RESOLVED
- cbergm7210
Well, this is disturbing...
Today when I went to start DP it now hangs on the splash screen. If I wait long enough it finally gives me an error message "Unknown Error" and when I hit Ok it just remains hung.
I've repaired permissions, trashed DP pref's, restored DP from Time Machine, reinstalled the 7.24 update, then finally reinstalled from the DP 7 DVD.
Ideas, anyone? I do have a tech link into Motu.
Chris
Chris
http://www.rfjmusic.com
- cbergm7210
Re: DP 7 Hangs On Startup
The Motu tech told me to pull the MIDI drivers and try again, but there was no difference.
Have ya tried starting with the option key down?
- cbergm7210
I'll try it, Mike.MIDI Life Crisis wrote:Have ya tried starting with the option key down?
EDIT: No change.
The MOTU tech also had me try starting with shift down to load MIDI only. No dice.
I was able to start Pro Tools 11 so no issues with MIDI / audio drivers there.
The day is waning...
Have you tried deleting the authorization file and re-authorizing. There's a thread here somewhere that tells you how to find that little bugger. I had to do that once and I vaguely recall the symptom being some sort of hang.
- cbergm7210
Game over. Looks like all but one USB port on my Mac Pro have gone out. I unplugged everything and DP booted up...now am troubleshooting another issue.
Re: DP 7 Hangs On Startup - RESOLVED
Ouch, sorry to hear that. Good luck!
I had the built in USB ports go out 2weeks ago. Disconnecting all USB and zapping PRAM fixed it.
- cbergm7210
Thanks, Mike! Would not have thought of that.MIDI Life Crisis wrote:I had the built in USB ports go out 2weeks ago. Disconnecting all USB and zapping PRAM fixed it.
EDIT: No dice.
- Shooshie
Dang! That's bad news, Chris. Do you have a backup computer?
There are inexpensive PCIe cards that will add another usb bus to your Mac Pro. I would use that as an opportunity to add usb 3.
