DP 7 Hangs On Startup - RESOLVED
cbergm7210
Post by cbergm7210 »
Well, this is disturbing...
Today when I went to start DP it now hangs on the splash screen. If I wait long enough it finally gives me an error message "Unknown Error" and when I hit Ok it just remains hung.
I've repaired permissions, trashed DP pref's, restored DP from Time Machine, reinstalled the 7.24 update, then finally reinstalled from the DP 7 DVD.
Ideas, anyone? I do have a tech link into Motu.
Chris
http://www.rfjmusic.com
cbergm7210
Re: DP 7 Hangs On Startup
The Motu tech told me to pull the MIDI drivers and try again, but there was no difference.
Have ya tried starting with the option key down?
cbergm7210
MIDI Life Crisis wrote:Have ya tried starting with the option key down?
I'll try it, Mike.
EDIT: No change.
The MOTU tech also had me try starting with shift down to load MIDI only. No dice.
I was able to start Pro Tools 11 so no issues with MIDI / audio drivers there.
The day is waning... :mumble:
Phil O
Post by Phil O »
Have you tried deleting the authorization file and re-authorizing. There's a thread here somewhere that tells you how to find that little bugger. I had to do that once and I vaguely recall the symptom being some sort of hang.
Phil
cbergm7210
Game over. Looks like all but one USB port on my Mac Pro have gone out. I unplugged everything and DP booted up...now am troubleshooting another issue.
Phil O
Re: DP 7 Hangs On Startup - RESOLVED
Post by Phil O »
Ouch, sorry to hear that. Good luck!
I had the built in USB ports go out 2weeks ago. Disconnecting all USB and zapping PRAM fixed it.
cbergm7210
MIDI Life Crisis wrote:I had the built in USB ports go out 2weeks ago. Disconnecting all USB and zapping PRAM fixed it.
Thanks, Mike! Would not have thought of that. 8)
EDIT: No dice.
Dang! That's bad news, Chris. Do you have a backup computer?
There are inexpensive PCIe cards that will add another usb bus to your Mac Pro. I would use that as an opportunity to add usb 3.
