MOTU 828 ORIGINAL - RECORDING PBM (ableton - soundforge)
nickmorisson
Post by nickmorisson »
Hi,
Just bought a 828 original, all ok when installing drivers and the sound work perfectly, i pluged my dj mixer on it.
The problem is when i want to record: tried on ableton live 8 and soundforge 10,
they recognize motu audio Asio (analog 1-2) no prob for that but can't hear anything then can't record nothing; it just bleep and crack (sometimes hear 1/2 seconds of a song)
(when bleeping, little signal comes in the meter of the recorder);
i'm on internal clock wave, 512samples, 44.1Khz (tried to put SPDIF, then i hear the sound but no signal at all for recording)
I'm on Xp Sp3 and just installed the latest driver for that: 3.6.7.3
Can someone find the issue?
Re: MOTU 828 ORIGINAL - RECORDING PBM (ableton - soundforge)
Moved to the MOTU Hardware Windows forum. Duplicate post removed.
torrentg
Post by torrentg »
If you want me to look over your system, I'll need the info.
Open a command prompt and type this then press Enter: msinfo32
File | Save on the opened screen.
Upload the saved file somewhere and paste a link here.
Other than that, to record and hear at the same time, you have to set the DAW track to be audible. Each software is different. You can also use CueMix (Motu's software mixing board) to monitor.
nickmorisson
Hi torrentg,
here the file: http://www64.zippyshare.com/v/77820180/file.html
Of course Live settings are on Asio: Motu audio
The cuemix console don't work with the 828 original (info from motu's site)
Thanx
nickmorisson
problem found and solved: my firewire cable was ••••, just changed and it works perfectly!
thanx
torrentg
Post by torrentg »
Wow, I'm surprised it was the cable! Great job figuring it out.
If trouble rears up again, let us know and we'll see what can be done.
Enjoy man! Glad for ya.
torrentg
Post by torrentg »
I was looking over things anyway and a huge red flag was obvious.
You should update your video card driver from NVIDIA.com. This is very old and the system will thank you much for it:
Code: Select all
Nom	NVIDIA GeForce 9600 GT
ID de périphérique Plug-and-Play	PCI\VEN_10DE&DEV_0622&SUBSYS_054510DE&REV_A1\4&3117C7BB&0&0080
Type de carte	GeForce 9600 GT, compatible NVIDIA
Description de la carte	NVIDIA GeForce 9600 GT
Mémoire vive sur la carte	512,00 Mo (536 870 912 Octets)
Pilotes installés	nv4_disp.dll
Version du pilote	6.14.11.7766
Fichier INF	oem3.inf (section nv4_G9x_HD)
Plans de couleurs	1
Entrées de table des couleurs	4294967296
Résolution	1280 x 1024 x 60 hertz
Bits/pixel	32
Adresse mémoire	0xFA000000-0xFAFFFFFF
Adresse mémoire	0xE0000000-0xEFFFFFFF
Adresse mémoire	0xF8000000-0xFBFFFFFF
Port E/S	0x0000BC00-0x0000BC7F
Canal IRQ	IRQ 16
Port E/S	0x000003B0-0x000003BB
Port E/S	0x000003C0-0x000003DF
Adresse mémoire	0xA0000-0xBFFFF
Pilote	c:\windows\system32\drivers\nv4_mini.sys (6.14.11.7766, 5,80 Mo (6 081 984 Octets), 26/06/2008 06:24)
You have the 9600 GT.
