I've moved all my VE-PRO plugins track to a single V-Rack. Now I realize I'd like to split them differently. I was hoping to simply duplicate the chunk and and edit the V-Rack but can't seem to find a way to do this. I also thought I could move all the plugins back to non V-Rack but can't see that option possible either.
I'd appreciate any tips.
thanks
Is removing a track from a V-Racks possible?
- ironchef_marc
New Rig |MAC Studio | OS12.6 | 64GB RAM | Storage | miniStack STX 18TB, (14TB HDD, 4TB SSD) | Crucial X8 4TB SSD |
Softwares | DP 11.22 | VEPRO7 | Audio Interface | M4 |
old rig | MAC Pro 2 X 2.26 GHz, 8-Core | 10.11.6 | 32 GB RAM | DP9.52 | 2408mk3 | MTP AV
- FMiguelez
Re: Is removing a track from a V-Racks possible?
You can temporarily move your tracks in a V-rack to the TO and do track operations there. Then you could port them back to the V-Rack.
You can also delete tracks directly from the V-Rack.
And you can also duplicate the V-Rack chunk and delete tracks as needed
- ironchef_marc
How do you do that?FMiguelez wrote:You can temporarily move your tracks in a V-rack to the TO and do track operations there. Then you could port them back to the V-Rack.needed
I just discovered the "delete track" at the very bottom of the channel strip, that little arrow, then you scroll all the way down. Well hidden!
- FMiguelez
Simply drag the V-Rack and drop it in the left part of a TO window.ironchef_marc wrote:How do you do that?FMiguelez wrote:You can temporarily move your tracks in a V-rack to the TO and do track operations there. Then you could port them back to the V-Rack.needed
- ironchef_marc
Thanks man! I didn't know that and couldn't find anything about it in the manual. You saved me a couple hours!FMiguelez wrote:Simply drag the V-Rack and drop it in the left part of a TO window.ironchef_marc wrote:How do you do that?FMiguelez wrote:You can temporarily move your tracks in a V-rack to the TO and do track operations there. Then you could port them back to the V-Rack.needed
