MIDI file Q... How to half or double tempo?
wonder
Post by wonder »
This may be a very dumb question...
I often work with people who will set there tempos to double what the tempo actually is (I'm guessing cause they don't know how to make their metronome click in 8th notes).
They'll send me MIDI files for piano or other VI's and they'll either be twice the tempo or half tempo. Either way ... I'd there a way to half or double a MIDI track to line up and fit in my properly tempo mapped DP session?
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
stephentayler
Re: MIDI file Q... How to half or double tempo?
Post by stephentayler »
I think this works - try locking the track before halving/doubling the tempo - I did a crude test 'by eye' and it seemed to work!
Then copy/paste or import to your project.
Cheers
SWT
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
wonder
Post by wonder »
I was trying to accomplish this in one DP session. Anyway to shortcut to a "scale tempo" of a MIDI track?
frankf
Post by frankf »
Try Scale Time, set to 50% or 200%
Frank Ferrucci
Frank Ferrucci
http://www.ferruccimusic.com
Post by Shooshie »
If scale time 200% doesn't work out exactly right, you can select all, then use the proportional drag to place one note exactly on the downbeat of that last measure, and the whole thing will adjust proportionately to fit.
[Proportional Drag = CONTROL KEY + drag. Add SHIFT key to constrain motion to one axis]
Percentage should work right, but someone reported a slight error in it in DP 8.0x. I don't know if that's been fixed yet.
Or maybe that error report was in Shift. Oh well, I don't remember. Just know that there are multiple ways of getting to what you want. Scale Time/Proportional Drag should do it quickly. If there is a conductor track there may be other complications. I haven't had to do this since the 1990s, so I don't remember. (I had to do it often back then, because metronome beats on subdivisions didn't always work during some version way back.)
wonder
Post by wonder »
the "Scale Time" seemed to work for the moment ... thanks a ton.
I'll try the other ways just for kicks to see which is simpler and easier.
thanks!
wonder
Post by wonder »
this is on a MIDI track BTW.
I'm trying CONTROL DRAG but DP not allowing me to. I think I'll stick to the Scale Time for now.
