Phasing Issues with DP 8
Dan Worley
Re: Phasing Issues with DP 8
Post by Dan Worley »
felicopter wrote:Uninstalled.
Reinstalled.
Same thing happens.
Now what?
I don't know. Call out to MOTU, I guess.
Is it this way on all projects?
Are you running Plug-ins in Real Time? Check that.
You can't get it to work with any plug-ins at all? (not that I think you should be forced to use those plug-ins, but just as a test.)
DP10.13
No one else is seeing this so I would stop looking at DP in and of itself and start looking at your other system components. Also, be sure your MON in the track isn't causing the phasing while recording.
Otherwise, Dan's right. Call MOTU, but if it ain't a DP problem, you still will have to check EVERYTHING in your system.
MIDI Life Crisis wrote: Also, be sure your MON in the track isn't causing the phasing while recording.
+1. I've been bitten by this more than once.
