vertical track size Medium
DP will not let me make any of my audio tracks larger than medium size (vertical) in the sequence editor in the song I am currently working on. Whether I drag it or select any size option larger than medium, that is as big as it will go. The project does have a large number of tracks than I' e probably used before, but I wouldn't think this alone would effect that. I can select any size I like in other smaller projects, it is just this one project as far as I know. It happened with the project when it was in DP7 and is still the case after opening it in DP8. I think I might be missing something obvious but I see no overall setting for this.
iMac 27" 4.2 GHz i7 1TB SSD. 40 GB RAM. Apogee One.
- bralston
Re: vertical track size Medium
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
Brian Ralston
