Liquid Mix and 64 Bit
stephentayler
Re: Liquid Mix and 64 Bit
Post by stephentayler »
I just tested Liquidmix - Mountain Lion, DP 8.01
works perfectly for me in 32 bit, and also in 64bit using JBridgeM.
Cheers!
SWT
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Giannis
Post by Giannis »
Ok, so if I get you right it runs, but you haven't done too much work with it?
Akoume - www.akoume.com
Akoume Blog - www.akoumeblog.net
stephentayler
Not much, I hardly use it anymore as I have other emulations I prefer. But it worked exactly as it used to. I have no idea how it holds up under stress though.
Cheers!
SWT
Giannis
Post by Giannis »
Ok, thanks!
stephentayler
I actually just tried it in 64bit on DP8.01 using JBridgeM, I managed to get 16 mono instances happily working, but no more - hmmm - I would have expected 32 - if I have time tomorrow I'll try the same test with stereo tracks, and also in 32 bit mode as well and see what happens!!
Pretty sure I used to be able to get 32 mono or 16 stereo.
Cheers!
SWT
Giannis
Post by Giannis »
I'm actually downloading Mountain Lion right now, so let's hope it works ;)
I'm not using many instances though, as I have many other great plug-ins.
stephentayler
OK - here are my findings
DP 8.01 - OSX 10.8.2
32 bit
Liquidmix AU - 32 mono or 16 stereo (as advertised!)
64bit
Liquidmix VST through JBridgeM - 16 mono or 16 stereo!
adding anymore crashes auxhost and DP
otherwise it seems to work as expected
Cheers!
SWT
Giannis
Post by Giannis »
Yes, I also got it to work seemingly well here, not testing that many instances though.
Strange also, since I got an email from Focusrite this morning saying it's only supported until 10.6 :)
Works well anyways!
