Liquid Mix and 64 Bit
Re: Liquid Mix and 64 Bit
I just tested Liquidmix - Mountain Lion, DP 8.01
works perfectly for me in 32 bit, and also in 64bit using JBridgeM.
Cheers!
SWT
Cheers!
SWT
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Ok, so if I get you right it runs, but you haven't done too much work with it?
Not much, I hardly use it anymore as I have other emulations I prefer. But it worked exactly as it used to. I have no idea how it holds up under stress though.
Cheers!
SWT
Cheers!
SWT
I actually just tried it in 64bit on DP8.01 using JBridgeM, I managed to get 16 mono instances happily working, but no more - hmmm - I would have expected 32 - if I have time tomorrow I'll try the same test with stereo tracks, and also in 32 bit mode as well and see what happens!!
Pretty sure I used to be able to get 32 mono or 16 stereo.
Cheers!
SWT
Cheers!
SWT
I'm actually downloading Mountain Lion right now, so let's hope it works
I'm not using many instances though, as I have many other great plug-ins.
OK - here are my findings
DP 8.01 - OSX 10.8.2
32 bit
Liquidmix AU - 32 mono or 16 stereo (as advertised!)
64bit
Liquidmix VST through JBridgeM - 16 mono or 16 stereo!
adding anymore crashes auxhost and DP
otherwise it seems to work as expected
Cheers!
SWT
32 bit
64bit
Cheers!
SWT
Yes, I also got it to work seemingly well here, not testing that many instances though.
Strange also, since I got an email from Focusrite this morning saying it's only supported until 10.6
Works well anyways!
Works well anyways!
