Click
Re: Click
Go to click preferences and make sure click is enabled for all time, or always whilst recording, rather than just for count off.
Re: Click
Or RTFM.
Rescinded as more info added by the o/p.
Last edited by MIDI Life Crisis on Wed Jan 02, 2013 4:07 pm, edited 1 time in total.
Re: Click
Thank you labman. I have done that and more. This only happens with DP8 not with DP 7.24. I have been using Performer and DP since their first version.labman wrote:Go to click preferences and make sure click is enabled for all time, or always whilst recording, rather than just for count off.
I wrote to technical support and they told me pulling the DP8 preferences
1. Quit DP8 (make sure to save any changes you've made to the open project).
2. Open a new window in the Finder, and navigate to Macintosh HD/Users/YOURUSERNAME/Library/Preferences/.
3. Drag the folder "com.motu.DigitalPerformer" from this folder to your desktop.
4. Re-open DP8.
I did it and still the same.
Re: Click
Wao what a funny guy. My dear friend I have been using Performer and DP since my first mac 512K. I think I know this DAW quite well. I am only trying to present this problem I have with DP8 that I do not have it in DP 7.2 and previous versions.MIDI Life Crisis wrote:Or RTFM.
Happy new year
Re: Click
Reinstall DP.
Re: Click
Sounds like a frustrating problem. (Also, I don't see how sitting around and reading the manual is going to solve something like THIS. --- Eeeesh.)
It occurred to me that there might be a couple little gremlins at work.
1. Perhaps auto-punch has been turned on? Or memory stop?
2. Perhaps there's a MIDI command being transmitted when you begin recording (check the commands). Sometimes those MIDI remotes do unexpected things.
3. Some other rig is sending some transport command?
- Shooshie
Re: Click
Does it shut down when you don't use a click at all?wilcro wrote:when I enable a track for recording, the recording stops after the 2 bars countoff click countoff. Help anyone please
DP 8.01
Mac OS X V.10.6.8
Re: Click
I had the same thing happen to me. I assumed the click preference had somehow changed to "only during countoff" but that was not the case. When I went in and re-entered all my click preferences it worked properly again.
I think this is an actual little bug.
Chris
Chris
M2 MacBook Air, DP11, MOTU MX-4, MOTU Mach5, EWQLSO Platinum, Acoustic Samples B5, UAD Waterfall Organ, EWQL Platinum Pianos, UVI Falcon, UAD-2 Duo, MOTU Ultralite mk5, K2600XS controller
