Kontakt 5 64-bit VST fails in DP8
Kontakt 5 64-bit VST fails validation in DP8. The 32-bit version passes as does 64-bit AU. I do not have this problem using Cubase. I'm use VST since I need to create projects for both Win and Mac (when the DP8 Win version finally is released).
Re: Kontakt 5 64-bit VST fails in DP8
F$%^&!!!! Unfortunately confirmed. Updated to K5 today. Oh well... Someday.
- zuul-studios
The VST Kontakt 4 (latest version) also fails in DP 8.01.
(At least the AU version passes.)
Computer:
Apple's M2 Mac Studio with 96 RAM; macOS X 14.5; 1 Internal SSD, 8 External SSDs, MOTU 828es audio device, AKAI MPK88 Keyboard Controller
Software:
DP11.31, Logic Pro X, FCPX, DaVinci Resolve; VSL's Super Package, VEPro 7 & MIR Pro, VI Pro 2; Altiverb 8; Cinesample's CineSympnony Complete Bundle; Native-Instrument's Komplete 13 Ultimate Collectors Edition, and many more VIs.
Software:
Is it VST 3 by any chance? I know VST 3 is not supported in DP 8.01.danika wrote:Kontakt 5 64-bit VST fails validation in DP8. The 32-bit version passes as does 64-bit AU. I do not have this problem using Cubase. I'm use VST since I need to create projects for both Win and Mac (when the DP8 Win version finally is released).
I didn't realize that K5 was the same sound set as K4. I know the format was altered, but given they're the same sounds and the AU for K4 seems to work I guess I spent $200 a bit prematurely. Oh well, could always use the deduction, and it is supporting a company who's products I use.
Supposedly, the filters are better in K5, so it sounds better than K4 overall.. but I'm not going to take the time to compare the two. I upgraded recently too (Komplete), and it's all I can do to change out K4 for K5 in my templates. However, in DP8, I have found that I can change 4 to 5 (AU) without having to reload the sounds, which is fantastic! Couldn't do that in 7.24.MIDI Life Crisis wrote:I didn't realize that K5 was the same sound set as K4. I know the format was altered, but given they're the same sounds and the AU for K4 seems to work I guess I spent $200 a bit prematurely. Oh well, could always use the deduction, and it is supporting a company who's products I use.
btw MLC, when you gonna write some notes on that sig line? Are you creatively dried up?
No, actually I'm open for business.Killahurts wrote:btw MLC, when you gonna write some notes on that sig line? Are you creatively dried up?
Good answer
- corbo-billy
Perhaps with the recent update to version 5.1 KONTAKT it's work fine ?
http://www.native-instruments.com/forum ... p?t=184141
Imac M4 24" under Sequoia 15.3.1 & Kontakt 8.2. _ Fireface800 X 2 _ FilterBank2 Sherman & Gibson Explorer Pro _ Virus C Desktop _ Adrenalinn III & Voyager Moog _ SpeakerPhone 2 _ PolyEvolver Keyboard _ Tempest _ D.P. 11.34 _
Indeed it does! You da man today!
- corbo-billy
Yup, that fixed the problem.corbo-billy wrote:Perhaps with the recent update to version 5.1 KONTAKT it's work fine ?
