Kontakt 5 64-bit VST fails in DP8
danika
Post by danika »
Kontakt 5 64-bit VST fails validation in DP8. The 32-bit version passes as does 64-bit AU. I do not have this problem using Cubase. I'm use VST since I need to create projects for both Win and Mac (when the DP8 Win version finally is released).
Re: Kontakt 5 64-bit VST fails in DP8
F$%^&!!!! Unfortunately confirmed. Updated to K5 today. Oh well... Someday.
zuul-studios
Post by zuul-studios »
The VST Kontakt 4 (latest version) also fails in DP 8.01. :( (At least the AU version passes.)
Computer:
Apple's M2 Mac Studio with 96 RAM; macOS X 14.5; 1 Internal SSD, 8 External SSDs, MOTU 828es audio device, AKAI MPK88 Keyboard Controller
Software:
DP11.31, Logic Pro X, FCPX, DaVinci Resolve; VSL's Super Package, VEPro 7 & MIR Pro, VI Pro 2; Altiverb 8; Cinesample's CineSympnony Complete Bundle; Native-Instrument's Komplete 13 Ultimate Collectors Edition, and many more VIs.
danika wrote:Kontakt 5 64-bit VST fails validation in DP8. The 32-bit version passes as does 64-bit AU. I do not have this problem using Cubase. I'm use VST since I need to create projects for both Win and Mac (when the DP8 Win version finally is released).
Is it VST 3 by any chance? I know VST 3 is not supported in DP 8.01.
I didn't realize that K5 was the same sound set as K4. I know the format was altered, but given they're the same sounds and the AU for K4 seems to work I guess I spent $200 a bit prematurely. Oh well, could always use the deduction, and it is supporting a company who's products I use.
Killahurts
Post by Killahurts »
MIDI Life Crisis wrote:I didn't realize that K5 was the same sound set as K4. I know the format was altered, but given they're the same sounds and the AU for K4 seems to work I guess I spent $200 a bit prematurely. Oh well, could always use the deduction, and it is supporting a company who's products I use.
Supposedly, the filters are better in K5, so it sounds better than K4 overall.. but I'm not going to take the time to compare the two. I upgraded recently too (Komplete), and it's all I can do to change out K4 for K5 in my templates. However, in DP8, I have found that I can change 4 to 5 (AU) without having to reload the sounds, which is fantastic! Couldn't do that in 7.24.
Killahurts
btw MLC, when you gonna write some notes on that sig line? Are you creatively dried up?
Killahurts wrote:btw MLC, when you gonna write some notes on that sig line? Are you creatively dried up?
No, actually I'm open for business.
Killahurts
Good answer :wink:
corbo-billy
Post by corbo-billy »
Perhaps with the recent update to version 5.1 KONTAKT it's work fine ?
http://www.native-instruments.com/forum ... p?t=184141
Imac M4 24" under Sequoia 15.3.1 & Kontakt 8.2. _ Fireface800 X 2 _ FilterBank2 Sherman & Gibson Explorer Pro _ Virus C Desktop _ Adrenalinn III & Voyager Moog _ SpeakerPhone 2 _ PolyEvolver Keyboard _ Tempest _ D.P. 11.34 _
Indeed it does! You da man today!
:woohoo:
corbo-billy
You must thank Native Instruments: I often wear the good news with my white beard . Image
danika
Post by danika »
corbo-billy wrote:Perhaps with the recent update to version 5.1 KONTAKT it's work fine ?
Yup, that fixed the problem.
