Anyway, the previous version of DP 8 which is the whole first one, you always from your installation DVD.MIDI Life Crisis wrote:Copy the old version before updating.
Do you know if they were exported as computed regions or as OMF effects? I've found that computed regions are more reliable, especially when you have crossfades.PJ wrote:OMF bug (from FCP) is still there.
I'm not sure, but I never had any problems with 7.24. I have open tech link and they are trying to fix this (I hope). I just have to import OMFs with 7.24 and then load them into 8.MIDI Life Crisis wrote:Do you know if they were exported as computed regions or as OMF effects? I've found that computed regions are more reliable, especially when you have crossfades.PJ wrote:OMF bug (from FCP) is still there.
That is so true. This really isn't the first time when I'm using older version for importing.MIDI Life Crisis wrote:It's a funny thing, but DP has always had issues with OMFs and AAFs in the past. It's been kind of hit and miss. One might work and the other wouldn't. Some OMFs work, others, not.
I just installed and I'm on the OS X that you described.Radiogal wrote:How is OSX 10.6.8 and DP 8.01 running now?
Is the monitor meter issue in 32 bit mode fixed??
Thanx.
Same nonsense here.hammerman wrote:That happened to me too. Use the link I got from twitter at the top of the thread and it will get you there. Or check manually within DP and it will get you there as well.Elektroakoustika wrote:Weird. Motu.com's download section says there are no updates available for my account. And I even checked to make sure my copy of DP8 is registered and it is....
Thanks Buzzybuzzsmith wrote:Addendum for Patricia.
Just opened a project that has:
...and 2 plugs...Inspector and Waves RVerb.
- Addictive Drums
Kontakt 3
Kontakt 4
Trilogy
MachFive 2
I'm redlined and got the "Digital Performer is running out of memory" message.
Sequence is playing, however.
Buzzy
Try this link:wvandyck wrote: I'm informed of the update in DP8 which takes me to the downloads area. No problem.
But if I log-in, I get the "no updates..." message. Weird.
I just did the update and it did leave the 8.0 copy. Hmm, I wonder what's the deal? Anywho, everything is working great!!!Gravity Jim wrote:Hey! The updater didn't create a second copy of DP.... it just left one application in the folder, and it's DP 8.01. Didn't it always used to make a new one, and then you'd have to throw the old one away?
But not surprising. If you are limiting yourself to 4GB or RAM you are going to get 4GB of RAM worth of memory and with several VIs you will redline.Radiogal wrote:
Disturbing.....
