DP 8.01 is released!
corbo-billy
Re: DP 8.01 is released!
Post by corbo-billy »
MIDI Life Crisis wrote:Copy the old version before updating.
Anyway, the previous version of DP 8 which is the whole first one, you always from your installation DVD. :wink:
Indeed, but this is a new way of DP updates, so future releases should be saved, either as the app itself or the installer. Just sayin...
PJ
Post by PJ »
OMF bug (from FCP) is still there. Volume curves are not imported right.
Those parts (in the picture) where volume curves are hidden, DP plays audio +6dB. Same OMFs are imported right with 7.24
PTHDN(TB)/OMNI / DP8 ** Post Production **
Guitar Gaz
Post by Guitar Gaz »
So far Reason Rewire in 64 bit seems to be working with DP 8.01. Fingers crossed. Lorne told me on the Tech Link.
Gary Shepherd
____________
PJ wrote:OMF bug (from FCP) is still there.
Do you know if they were exported as computed regions or as OMF effects? I've found that computed regions are more reliable, especially when you have crossfades.
PJ
Post by PJ »
I'm not sure, but I never had any problems with 7.24. I have open tech link and they are trying to fix this (I hope). I just have to import OMFs with 7.24 and then load them into 8.
BTW my graphics are flying with 8.01 :)
It's a funny thing, but DP has always had issues with OMFs and AAFs in the past. It's been kind of hit and miss. One might work and the other wouldn't. Some OMFs work, others, not.
PJ
Post by PJ »
MIDI Life Crisis wrote:It's a funny thing, but DP has always had issues with OMFs and AAFs in the past. It's been kind of hit and miss. One might work and the other wouldn't. Some OMFs work, others, not.
That is so true. This really isn't the first time when I'm using older version for importing.
buzzsmith
Post by buzzsmith »
Radiogal wrote:How is OSX 10.6.8 and DP 8.01 running now?
Is the monitor meter issue in 32 bit mode fixed??
Thanx. :)
I just installed and I'm on the OS X that you described.
After 2 minutes, no problems to report.
Memory meter is still showing pretty high on a project that has lots of plugs but no VIs. About 2/3rd of the meter is occupied with the greenish yellow bar.
No red.
As I mentioned earlier (maybe on Facebook), I'm just ignoring it!
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
buzzsmith
Post by buzzsmith »
Addendum for Patricia.
Just opened a project that has:
  • Addictive Drums
    Kontakt 3
    Kontakt 4
    Trilogy
    MachFive 2
...and 2 plugs...Inspector and Waves RVerb.
I'm redlined and got the "Digital Performer is running out of memory" message.
Sequence is playing, however.
Buzzy
Focal Twin6 Be(s)
wvandyck
Post by wvandyck »
hammerman wrote:
Elektroakoustika wrote:Weird. Motu.com's download section says there are no updates available for my account. And I even checked to make sure my copy of DP8 is registered and it is....
That happened to me too. Use the link I got from twitter at the top of the thread and it will get you there. Or check manually within DP and it will get you there as well.
Same nonsense here.
I'm informed of the update in DP8 which takes me to the downloads area. No problem.
But if I log-in, I get the "no updates..." message. Weird.
Radiogal
Post by Radiogal »
buzzsmith wrote:Addendum for Patricia.
  • Addictive Drums
    Kontakt 3
    Kontakt 4
    Trilogy
    MachFive 2
Buzzy
Thanks Buzzy :)
Disturbing :(
You are running in 32 bit right?
Why don´t you run in 64 bit and use jbridge?
Just cusious for stability.
Still hesitaing to upgrade to DP8. got the box right here.....
NazRat
Post by NazRat »
wvandyck wrote: I'm informed of the update in DP8 which takes me to the downloads area. No problem.
Try this link:
http://www.motu.com/download/download_m ... tform_id=2
DP8.06 PT11.2.0 VEP 5.3.x
rodger1811
Post by rodger1811 »
Gravity Jim wrote:Hey! The updater didn't create a second copy of DP.... it just left one application in the folder, and it's DP 8.01. Didn't it always used to make a new one, and then you'd have to throw the old one away?
I just did the update and it did leave the 8.0 copy. Hmm, I wonder what's the deal? Anywho, everything is working great!!! :headbang:
Mid 2012 Mac Pro 12 Core 2.4GHz, 24G RAM, OSX 10.8.2, DP 8.01
4x2 TB Hard Drives
APOGEE Symphony
MOTU 2408 mk3
MOTU HD192/Black Lion Modified
MOTU 24I/Ox2
MOTU MIDI Timepiece
Universal Audio UAD-2 Quad x 2
Universal Audio (Entire Plugin Library)
Waves Mercury+ Studio Classics
Tons of other goodies; to many to mention here
Radiogal wrote:
Disturbing :( .....
But not surprising. If you are limiting yourself to 4GB or RAM you are going to get 4GB of RAM worth of memory and with several VIs you will redline.
I'm stubbornly working in 64 bit only and have no issues. Only running about 14 instruments but also a hi-res quicktime across two monitors.
The whole point of DP8 for me is 64 bit. No more unused RAM. No more redlines.
:koolaid: :mrgreen:
