Can I use DP8 in 64 bit mode with a Mac that's EFI 32 bit?
screws
Post by screws »
Like it asks in the subject, I'm itching to upgrade to DP8, but I've got a Mac Pro 1,1 (32 bit EFI) and I'm not sure it will give me the things I really want. The most important question is whether I'll be able to access all 16 GB of ram.
Here's the deal as I understand it. I run Snow Leopard [10.6.8] but it can't boot into 64 bit mode according to this article - http://www.everymac.com/mac-answers/sno ... -mode.html
I think that means there is no access to anything beyond 4GB of ram. If I'm wrong, please tell me.
Steve Cruz
Cruzified Music Productions
Florida
FutureLegends
Re: Can I use DP8 in 64 bit mode with a Mac that's EFI 32 bi
Post by FutureLegends »
We've gone through this a million times. Search the forum.
The short answer is: YES, you can use DP8 in 64bit and access more than 4gb or ram.
bralston
Post by bralston »
Steve's question has actually not been asked a lot before. Because his is different.
Welcome Steve.
If you computer can not boot into the 64-bit Kernal (which Apple says it can not)...then you will be dafaulting to 32-bit mode because the OS is not in 64-bit. And unfortunately in 32-bit mode...you will be limited to the 4GB of RAM just as before. So...unless you can find a hack (which may exist)...to run your MacPro with the 64-bit Kernal...you may be out of luck with 64-bit DP (Or any other true 64-bit program).
The program will still run...but it is having the OS under the 64-bit Kernal as well as the program in 64-bit mode that lets you access all of the RAM. So your suspicions are correct.
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
bralston wrote:The program will still run...but it is having the OS under the 64-bit Kernal as well as the program in 64-bit mode that lets you access all of the RAM. So your suspicions are correct.
Brian... I'm sorry but I'm pretty sure this is not correct. You do not have to be booted into the 64-bit kernel to run DP in 64-bit mode and allow DP to access more than 4GB RAM. We have gone over this before.
Look at this thread starting here part way down page 9 of it and continuing into 10. It's pretty clear DP8 can access more than 4GB of RAM if launched in 64-bit mode on a MacPro 1,1 booted in the the 32-bit kernel.
http://www.motunation.com/forum/viewtop ... &start=120
bralston
Post by bralston »
Then thank you James. And sorry for further confusing the issue. I guess this is what I get after coming out from being busy on a film for a while.
Then Steve, seems like you are good to go.
Regards,
Brian Ralston
bralston wrote:Then thank you James. And sorry for further confusing the issue. I guess this is what I get after coming out from being busy on a film for a while.
Hey Brian... I understand completely! It's been a very confusing subject and one we're all trying to wrap our heads around. And from what I've heard, manufacturers may eventually not update 32-bit kernel extensions (which I believe is what "drivers" are) to hardware like audio interfaces, and I'll be stuck at that point. :(
Post by Shooshie »
Don't worry, Brian. We didn't have a final answer to this question until someone with a Mac Pro 1.1 (32 bit kernel) actually booted DP in 64 bits and showed us that it was using more memory than previously allowed. We had lots of evidence that this would be the case, including articles by very knowledgeable people, but there was always a catch that made us wonder, "did they consider THIS?" So, it was one of those 90% sure things, that didn't become 100% until we had the empirical evidence. Few questions have so plagued us for an answer as this one.
mikeka
Post by mikeka »
The answer as FL stated is yes! There is no doubt. I have a Mac Pro 1,1 (32 bit EFI) with 7GB RAM. I've been using DP8 64 bit and have easily accessed more than 4GB RAM. Just for kicks I loaded 9 instances of Trilian with the acoustic bass patch and one instance of Ivory 2 (Bosendorfer) for a total DP usage per the activity monitor of 5.79 GB. I do have a screen shot to post but don't know how to do that here.
DP 8.07 64 bit, OS 10.10.5, Mac Pro 5,1 12-core 3.33ghz, 16GB ram, lots 'o plugs and VIs
Dan Worley
Post by Dan Worley »
Same here. I have a Mac Pro 1,1 (32 bit EFI). DP has access to more RAM and is working perfectly. I'm only experiencing a few minor glitches with the GUI and menus, everything else is working wonderfully. I'm very pleased. Snow Leopard 10.6.8.
DP10.13
