Jim, here's my GPU:Gravity Jim wrote:I'm curious as to what video card to have in your quad core. Some forum members reporting laggy UI are zeroing in on the GPU as the culprit.
ATI Radeon HD 5770, 1024 MB graphics
It does, but only for that restart. To start up in 64 bit by default use the terminal command shown here. http://support.apple.com/kb/HT3773?view ... cale=en_USsampolfonz wrote:Restart Mac Pro by holding down the 6 and 4 (they tell me this re-starts in 64 bit).
Do you always boot into 64-bit kernel. It's not necessary to run DP in 64-bit mode. Try booting in 32 bit and then running DP. Are the MOTU audio drivers 64-bit? I'm assuming they must be if they work in 64-bit boot.sampolfonz wrote:Restart Mac Pro by holding down the 6 and 4 (they tell me this re-starts in 64 bit).
Ditto!twistedtom wrote:dewdman good post and right on.
By "system specs", we meant the following:sampolfonz wrote:Here are the specs from System info:
NVIDIA GeForce GT 120:
Chipset Model: NVIDIA GeForce GT 120
Type: GPU
Bus: PCIe
Slot: Slot-1
PCIe Lane Width: x16
VRAM (Total): 512 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x0640
Revision ID: 0x00a1
ROM Revision: 3386
Displays:
SyncMaster:
Resolution: 1680 x 1050 @ 60 Hz
Pixel Depth: 32-Bit Color (ARGB8888)
Display Serial Number: HVYLB00457
Mirror: Off
Online: Yes
Rotation: Supported
VX2739wm:
Resolution: 1920 x 1080 @ 60 Hz
Display Serial Number: RKD102102424
Main Display: Yes
Mirror: Off
Online: Yes
Rotation: Supported
