Can I connect my 828 mkii s/pdif to nearfield bnc?
doc7string
Post by doc7string »
I am using an 828 mkii, plugging mic into a pre then to the 828 which then goes to my MAC. I would like to buy a pair of Neumann KH120 d monitors and hook it up as noted in my subject header. I have seen available cables online (rca to bnc) making me believe this will work, but I wanted to ask if I am right. I'd prefer a digital connection over analog if possible. If not maybe I will just go analog, or even consider my seco d mo itor choice Adam A7x.
27" iMac, 3.4 gHz, 32 GB ram, MOTU 828 mkII, DP8, Mac OS X 10.8.3 http://www.myspace.com/paulwillisproject
http://www.myspace.com/paulwilliscountry
stevemilnersound
Re: Can I connect my 828 mkii s/pdif to nearfield bnc?
Post by stevemilnersound »
You absolutely can use the S/PDIF outputs on the 828 for this. All you would need is a simple BNC-RCA cable (Full Compass has plenty of options in stock) or if you've already got some good cables, you can spend a couple of bucks each on an RCA to BNC adaptor (typically $1.99/ea).
Those monitors also accept AES3, as well as Analog inputs and can switch between the three inputs as the need arises. Those are some deluxe monitors... hope you have fun with them!
Steve
doc7string
Thanks so much Steve for the info. Im very excited about them. I just hope that my ear is half as deluxe as they are so that I can take advantage of them.
noomi
Post by noomi »
Intel Core i7 3820 computer with 12GB Corsair DDR3 1333Mhz RAM. Asus P9X79 Motherboard. Crucial M4 SSD. Dual Full HD monitors. PCI424 with MOTU 24IO. MOTU MIDI Express 128 USB. Steinberg Cubase 6.5. Various VST plugs. Steinberg Houston controller. Clavia Nord Rack 2x. Yamaha CS-1X. Behringer Eurodesk MX2442. Akai s2000 sampler. Roland MC-303 Groovebox. Various outboard.
Latest JN0-660 dumps practice questions delivers in depth understanding so you will pass real exam on time. Also see more details on University of California, San Diego and Anabaptist Mennonite Biblical Seminary website and Youtube or Facebook best of luck.
stevemilnersound
Okay...
