One word of advise is saving pre sets.SixStringGeek wrote:
I've been banging on the memory ceiling for awhile and ended up springing for Vienna Ensemble Pro to move plugs out of the DP address space. It works for both 64 and 32 bit plugins (two different servers). I've started putting all my instruments in it.
So if you gotta have a solution - there it is.
I actually think a nice solution would be for DP to add plugins servers and always run them outside of DP. This would make the main app more stable. Even just doing a 32-bit version would be cool.
A user will most likely have to save the pre set of any given multi or plug in using DP 7.After, move to DP 8, run the 32 bit VE Pro, load the VI and its pre set.
