DP closes itself while recording a concert: everything LOST!
Re: DP closes itself while recording a concert: everything L
Maybe a minimal set of plugs...
best
Klaus
best
Klaus
Thanks for all your tips.
Anybody knows where DP7 puts temporary audio files while recording?
DP 8.04, MacBook Pro 2.2 Core i7 17" 8GB, RME Fireface 800 + Presonus Digimax FS (3x), Snow Leopard 10.6.8
- FMiguelez
They are located in the Audio Files folder wherever you stored your DP session, by default. This happens when they get written and saved normally. Some people have been able to recover some files from the Trash when DP crashes in the middle of recording.
Have you checked if there's something there about your concert?
I checked in that folder with Terminal while recording but it was empty!
- Pappy725
Yes, that's what happened to me...cioto wrote:You mean all the audio recorded up to that point was available in the trash and you recovered it this way?Pappy725 wrote:.. It should have come up with a message about recovering the files. Mine were always in the trash. Drug them out to the desktop, restarted DP and recorded the second set.
Pappy
Pappy
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
I found where DP puts temporary audio:
Volume_Name/.TemporaryItems/folders.501/TemporaryItems/
At least I know where to look for them, in bad events...
Anyway, this evening I have just finished a test: 26 tracks recording, I stopped after 4 hours, everything OK. Maybe the issue was related to the firewire cable I used to connect to the fireface 800: a firewire 800 to 400 adapter and a firewire 400 cable. Today I used a regular firewire 800 cable and everything has been fine. I hope it will be the same tomorrow during the show!
Rob
Rob
Just a quick thought: there was a thread recently where someone was recording at a concert and had the hard drive shut down because of heavy vibrations that triggered the safety mechanism that protects the drive from damage caused by rapid movements. Is it possible that happened in your case?
Whatever it was, good luck with the concert tomorrow.
Mhhhhh.... Thanks for your thought!!!
I'll check this too, I'll start moving the drive while recording some test tracks. Anyway I had some issues with the GUI (slow refresh) before the crash, and I don't think this is a drive related problem. But I'll check for sure.
Thanks for your help!
I *THINK* I found the issue.
I noticed that the GUI becomes slow and jerky if I set the horizontal scale (in tracks or sequence window) so large that I can see 30-45 or more minutes of audio (6/8 songs) alltogether in the window while recording.
This happens in tracks and sequence windows too.
If I zoom in horizontally so that the window displays only a smaller part of the show, the GUI immediatly returns to behave OK and smooth.
Maybe DP has to keep reference on the graphic waveform of all the tracks displayed in the window and if the tracks ar many and long, it starts having troubles...
Could you please test this on your systems?
Rob
Rob
