MIDI Life Crisis wrote:Yet, many have the same drivers and devices working, which may indicate a conflict with some other driver or component in your particular system.
the problem is that If I hook up only 'one' unit .. it works work perfectly.. its when I add the second units problems surface!
which ever unit is NOT directly connected to BNC (i.e clocking from the 424 card) clicks and pops... I can swap the bnc cable to the other 2408.. set that to wordclock and suddenly.. the first unit now pops and clicks!
the main drawback I have on this forum is that nobody seems to have a similar setup to me (i.e. 2 x 2408 M3's and a 424 card)... I just find it strange that the only person on here I 'have' found who has 2 x 2408's... also has a mackie dxb and cubase 6.. (but a mac instead of a pc) ... and is having exactly the same problems... and I mean.. exactly the same!!! do 'you' not find that odd!
as for a conflict with my system.. I don't think that is the case.. I have tried 3 different pc's .. all with windows 7 64bit... but different motherboards, cpu's and graphic cards... and all disply the same problem!
currently my main daw pc has been re-formatted (yet again)... latest chipset drivers loaded and the 424 drivers and card... and thats it, nothing else.. no other cards, software or drivers! but still no joy!
Now to add to the confusion.. when I check the properties for each set of audio outputs.. (24 pairs in total) windows says I have only the option of either '16bit 44.1' or '16bit 48' .... no 24 bit or 96k ... (I have also seen this situation in another post from another user somewhere on this forum). again... very odd!
my next step it to get hold of a bnc t-link so I can slave both units to wordclock in the hope that the second unit will lock... as I am sure this is where my problem lies... that second unit is not locking properly via the 424 card.... yeap, it's a long shot... but I am rapidly running out of things to try!
and I can forget about setting the 424 card to internal and my mackie to slave... the digital noise is 10 times worse on all 48 channels!
p.s... there is nothing wrong with my mackie clock cards (apogee)... I have three (bought as spares for the future use because the desk is now discontimued) and they all work fine!
