Is there a trick to getting et1 to work?
kinnylandrum
Post by kinnylandrum »
I need a tuner that works with DP 4.6. I tried the eMagic tuner, et1, and although it works with 4.5, it doesn't with 4.52 or 4.6. I think it might just be some installation weirdness. Can anyone get this to work with 4.6 without an error message, or is there some other alternative? Thanks.
BKK-OZ
Post by BKK-OZ »
I've only ever used it in 4.12, but it is finicky.
Never put it on a surround-track, bam! it'll crash everything.
Never put it in a signal chain btwn other things, bam! it'll crash everything.
I only use while tuning up, and as an insert in an audio (not Aux) track and I get rid of it (not just bypass, but I get rid of it) before doing anything else within DP.
Used in that way, it works. Given that its free, they may not have updated it for Tiger, et al.
Cheers,
BK
- M Kaku
IIIGmusic
Post by IIIGmusic »
All I can say is that there seems to be some incompatibility with 4.6. Your issue is exactly like mine with et1(works in previous versions) and i can't seem to find a solution anywhere. I don't believe it has to do with tiger.
+1 person looking for an answer! :)
kinnylandrum
Thanks for the replies. I guess it won't work. Does anyone know of another tuner I can insert as a plugin? Otherwise, to check the tuning of a sample coming from my computer, I have to hold a tuner up to the speaker. It looks really unprofessional but routing the audio to the input of a handheld tuner is WAY too much hassle.
