More instances or more channels?
Given my config (below), should I be using more instances of K4 & PLAY, or using 16 MIDI channels per instance of my VI's? Trying to get the best balance of performance possible! If there is a previous thread regarding this please advise. Thanks!
Mac Studio(2022) M1 Max/64GB
MacBook Pro 16” M3 Max
DP 11.3 • Sibelius Ultimate
- cbergm7210
Re: More instances or more channels?
From what I've been informed, PLAY does better opening a new instance for each instrument and Kontakt is better to load up instruments in one instance. Also, EW says to load PLAY instruments before Kontakt for better memory management.
http://www.rfjmusic.com
Interesting info, thanks. How do you set up PLAY to load first?
- cbergm7210
I host all my VI's in VE Pro. It loads things in order of how they are in the instance, so I move all the PLAY VI's to the beginning of the setup.
