MachFive 3 with Pro Tools 10, Nuendo 5, etc. ?
Yukulele
Post by Yukulele »
Hello folks,
I've put MachFive 2 on hold for a long time now, due to several problems i got with latest Pro Tools releases (RTAS), ie. CPU spikes mostly (unusable).
I tried to sold it years ago (support concerning MachFive 2 bugs i encountered with Pro Tools was just inexistent, and i tried several times to report issues in the MOTU support area !), but no one jumped in...
So i'm wondering if things are better now, and if i should upgrade to v3... I already "lost" 200 euros from v1 to v2, so i don't want to make the mistake again !
I'm not using DP anymore, but Pro Tools 9, Nuendo 5, and Pyramix 7 (OS X and Windows, i need both environments, and full compatibility between PT and Nuendo).
I don't care about the soundbanks, i just need stable 5.1 and 7.1 instances to layout homemades sounds (footsteps, gunshots, pads, drones, etc.) to picture works.
OS X.6.7 and Windows 7 64bit, on a MacPro.
Any feedbacks with these kind of setups ? BTW, is MachFive 3 64bit compatible ? If not, i will just not upgrade, this will just be unacceptable for a VI sampler in 2011 IMHO...
I'm really reluctant to upgrade, as support for MachFive 1 & 2 (no update for almost 3 years !) was quite inexistent, but if it works now, at least, i'm willing to spend the money and get back to work with it.
Sound Designers.Org founder
Mac Pro 2,66GHz - 5GB RAM - OS X.5.8 - M5 2.02
Yukulele
Re: MachFive 3 with Pro Tools 9, Nuendo 5, Pyramix 7, etc. ?
Post by Yukulele »
I guess everyone is using Digital Performer here ? Well, i'll hold my breath then, until i get positive feedbacks with other DAWs, especially Pro Tools 9 and Nuendo 5.5 (OS X and Windows 7).
hugy
Post by hugy »
M5v3 is 64bits compatible on PC(in all 64bits host) and on Mac(in standalone and 64bits AU hosts)
Can't say for your other question.
Yukulele
Post by Yukulele »
Thanks Hugy, i guess the VST Mac release is also 64bit compatible ? To summarize, only RTAS, both Mac and Win, is 32bit only for now ?
hugy
Post by hugy »
Yukulele wrote:Thanks Hugy, i guess the VST Mac release is also 64bit compatible ? To summarize, only RTAS, both Mac and Win, is 32bit only for now ?
Not currently, but I suppose this is planned in a near future.
ziggstar
Post by ziggstar »
I'd love to know this as well - also abandoned M52 as it is not compatible with PT8. I have high hopes for M53 but need to know if it will work or if I need to go back to sequencing in DP just to use M5 sounds.
Anyone from MOTU weigh in please?
tastythedog
Post by tastythedog »
I've just started trying to use it with PT 9 and it's crashing constantly. Logic has been fine so far. Too bad cause otherwise I'm loving it.
hugy
Post by hugy »
PT is only 32bits as opposed to Logic so if you load all the scripted instruments maybe you are running low on RAM which could explain crashes ?
Yukulele
Post by Yukulele »
Other experiences with Pro Tools and Nuendo both on OS X.6 and Windows 7 since last october ?
Yukulele
Post by Yukulele »
tastythedog wrote:I've just started trying to use it with PT 9 and it's crashing constantly. Logic has been fine so far. Too bad cause otherwise I'm loving it.
Any new experiences with latest M5.3 updates and eventually Pro Tools 10 ?
ziggstar
Re: MachFive 3 with Pro Tools 10, Nuendo 5, etc. ?
Post by ziggstar »
Bump
Also curious about upgrading Pro Tools. Currently M5 3.1 runs great on my Pro Tools 8LE system, but I'm looking to upgrade to PTX. Has anyone tried this yet?
