Digidesign MBox2 announced
pcm
Post by pcm »
You can read about it at the Digi site.
Most notable is what it DOESN'T have.
-no firewire (still USB)
-no 96k (still maxes out at 48k)
-no price reduction (still $495 list)
All that seems to be changed is the addition of MIDI i/o, and the ability to record on both the analog and digital inputs at the same time. Snore.
Considering what they could have done, I'm astonished that this is all they could come up with after all these years.
sdfalk
Post by sdfalk »
Having an M-Box myself I agree.
I looked at and wasn't even slightly interested in (ahem)
"upgrading" to that one
But ummm nice box though :lol:
A Metric Halo ULN8-3D…mmmmmmm
danes
Post by danes »
I notice that focusrite's preamp is not available in version 2, no?
G5 1,8Ghz|OSX 10.3.9|DP 5.1|Kontakt|Reaktor|Reason|Waves Diamond 5
sdfalk
Post by sdfalk »
I'm starting to wonder, what's in a name?
The focusrite preamps on my M-Box sound like dog poo.
mersis
Post by mersis »
sdfalk wrote:I'm starting to wonder, what's in a name?
probably because digi didnt wajnt the good oines
as you can see they dont care about their products
hence Mbox 2
sdfalk
Post by sdfalk »
No argument from me.
I have Protools just to keep up with it and run a few sessions from time to time and that's about it
chaim
Post by chaim »
wonder
Post by wonder »
i just bought the OLD mbox yesterday. I need PT as a transfer because all the other studios use PT and not DP.
I tried to play a SMALLLLL project and kept getting alerts to increase buffer.
is USB just not even possible at ALLL with recording?
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
dix
Post by dix »
Is that weird arm thing on the front permanent or will I have to saw it off?
sdfalk
Post by sdfalk »
wonder wrote:i just bought the OLD mbox yesterday. I need PT as a transfer because all the other studios use PT and not DP.
Of course it is..
I've done it often
Not sure what your problem is though
wonder
Post by wonder »
as i stated, the recording/playback keeps stopping and says the USB is not working properly and to INCREASE MY BUFFER size. My buffer size is TOTALLY maxed out.
Are there bottlenecks when running USB through a HUB?
sdfalk
Post by sdfalk »
Running through a hub with an M-Box is a bad idea.
If that's what you're doing, that could be most of your problem
right there.
Give the M-Box its' own usb port.
Which tells me you turned the buffer setting up, but doesn't explain
what could be causing your problem
wonder
Post by wonder »
i have no idea what would be causing that problem. im assuming its the HUB or some other issue.
sdfalk
Post by sdfalk »
If you're plugged into a hub, STOP
Plug directly into a FREE available USB port..
NO HUBS!
It's in the M-Box manual as well.
Remember, you're dealing with pretty limited bandwidth
in USB 1.
That's not to say you can't use it for recording, but plugging
into a hub with (potentially) other devices will cause problems.
wonder
Post by wonder »
sweet, thanks sdfalk!
appreciate it.
we dont need no stinking manuals!!!!
