Digidesign MBox2 announced
You can read about it at the Digi site.
Most notable is what it DOESN'T have.
-no firewire (still USB)
-no 96k (still maxes out at 48k)
-no price reduction (still $495 list)
All that seems to be changed is the addition of MIDI i/o, and the ability to record on both the analog and digital inputs at the same time. Snore.
Considering what they could have done, I'm astonished that this is all they could come up with after all these years.
- sdfalk
Having an M-Box myself I agree.
I looked at and wasn't even slightly interested in (ahem)
"upgrading" to that one
But ummm nice box though
A Metric Halo ULN8-3D…mmmmmmm
- sdfalk
No argument from me.
I have Protools just to keep up with it and run a few sessions from time to time and that's about it
i just bought the OLD mbox yesterday. I need PT as a transfer because all the other studios use PT and not DP.
I tried to play a SMALLLLL project and kept getting alerts to increase buffer.
is USB just not even possible at ALLL with recording?
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
Is that weird arm thing on the front permanent or will I have to saw it off?
- sdfalk
Of course it is..wonder wrote:i just bought the OLD mbox yesterday. I need PT as a transfer because all the other studios use PT and not DP.
I've done it often
Not sure what your problem is though
as i stated, the recording/playback keeps stopping and says the USB is not working properly and to INCREASE MY BUFFER size. My buffer size is TOTALLY maxed out.
Are there bottlenecks when running USB through a HUB?
- sdfalk
Running through a hub with an M-Box is a bad idea.
If that's what you're doing, that could be most of your problem
right there.
Give the M-Box its' own usb port.
Which tells me you turned the buffer setting up, but doesn't explain
what could be causing your problem
right there.
- sdfalk
If you're plugged into a hub, STOP
Plug directly into a FREE available USB port..
NO HUBS!
It's in the M-Box manual as well.
Remember, you're dealing with pretty limited bandwidth
in USB 1.
That's not to say you can't use it for recording, but plugging
into a hub with (potentially) other devices will cause problems.
NO HUBS!
in USB 1.
