Heat problem
Heat problem
Sorry, I couldn't find a better place to ask.
Is it ok to put my laptop (15" MBP) on traveler cause it gets hot after an hour.
I usually record at different places and this way doesn't take so much space but heat makes me worry about it.
There is special gel for cooling laptops.Did you ever use them between these two?
thanks
thanks
MBP 15"(i7 2.0Ghz),snow leopard (10.6.7), WDstudio(1TB/FW800-usb2)
Motu Traveler mk3, Genelec 8020a,Yamaha NS10-M, Sennheiser MKH40,MD421,Beh C2, M-Audio Microtrack II
- FMiguelez
Re: Heat problem
I personally would never place a laptop over an audio interface because of the heat.
If you must do it, I'd suggest you get some kind of small platform with four rods, so most of their bodies don't touch each other. You should leave a few centimeters of space between them.
Kind of the exact opposite you want during ... never mind!
Re: Heat problem
For now I use a short,thick cable between them.It gives about the centimeter distance for breath.
Any other portable suggestion would be appreciated.
Re: Heat problem
+1 You can buy these at most home improvement stores. Cheap and they help a lot. I put those on the bottom of my iBook and having that room for air to circulate underneath is a big help.cuttime wrote:Adhesive vinyl bumpers.
Re: Heat problem
You might find it more convenient to install the bumpers to the top of your interface.
Re: Heat problem
What do you think about these three?
http://www.blueunplugged.com/Griffin-La ... ptops.aspx" onclick="window.open(this.href);return false;
http://www.blueunplugged.com/GEL-Coolin ... Stand.aspx" onclick="window.open(this.href);return false;
http://www.blueunplugged.com/Cool-Alumi ... Stand.aspx" onclick="window.open(this.href);return false;
The last one is very easy to make.
The Gel mat is also cool.
