Anyone use Apogee X-Firewire with DP?
Would be very interested in any experiences good or bad.
<small>[ August 22, 2005, 01:34 AM: Message edited by: dwood ]</small>
Dual G4 450 w/1.5 GB ram, 10.4.3, Mytek 8X96->2408MkII/PCI-324, ATTO UL3D SCSI w/ Atlas 10k RPM, USB Fastlane, DP 4.6.1, Various Plugz, Reason 2.5 etc.
Apogee X-Firewire with DP is fine
I have been using Apogee X-Firewire with DP 4.6 and my Rosetta 200 and it is working great.
G5 Dual 1.8, (NO AMD's, NO PCI-X) OS 10.42, 120 GIG 7200 RPM SATA Audio Drive, 2 X 250 Gig EZQUEST A/V Firewire drives, DP 4.6, Apogee Rosetta 200 w/Firewire card, MOTU 828MK11, UA LA-610, UAD-1 X 2, BFD Drums, Mach5, Battery2,Wife, Dogs X 2, and a little house out in the country!
- qo
I had the same problem with the AD/DA-16X. Audio/MIDI Setup Aggregate Devices solved it for me (assuming you're using Tiger). Even if you have one device, it seems to work and allows for much more flexibility in Priority settings.bradswan wrote:I'm using the rosetta 800 with x-firewire into DP. The only way it works for me is to run at low priority, otherwise i get unbearable crackling.
To answer Splinter, yes the Rosetta 200 is AD-DA at the same time.
dwood, I use low priority, buffer 512, host buffer multiplier x1, and record at 4800/24.
I was using the 828mkll as an interface but am now using it mostly as a doorstop since I got the Roesetta 200. I layer acoustic/electric guitars, bass, and vocals one at at time so it works for me that way. I only use the 828 when I have a drummer come in and play a drum Kat and I record his samples and MIDI. I will run the snare and kick through the rosetta and the other drums through the 828.
I mix ITB so all I need is the Rosetta and it works great for me.
Thanks for the response. I couldn't tell from Apogee's info if I could use it as my main D/A while recording through it for an A/D. This makes this device much more appealing. I'd also use it as a master clock. I can't envision getting the FW card for it though and would probably connect it via lightpipe to my 2408III, which, with my Digimax, gives me 18 inputs. Much more than I usually need.jcar wrote:To answer Splinter, yes the Rosetta 200 is AD-DA at the same time.
So how does it sound? Is it up there with the AD-16X and Rosetta 800?
- davedempsey
Splinter,
I use the Rosetta 200 as main in and out via s/pdif with my 828Mk2 - the sound quality is superb. The extra facilities offered by the Coda Audio Finishing Module make this piece great value. I've not looked at the X card option at this time.
Dave
Dave
Lots of stuff and a recently acquired ability to stop buying
