Anyone use Apogee X-Firewire with DP?
dwood
Post by dwood »
Would be very interested in any experiences good or bad.
<small>[ August 22, 2005, 01:34 AM: Message edited by: dwood ]</small>
Dual G4 450 w/1.5 GB ram, 10.4.3, Mytek 8X96->2408MkII/PCI-324, ATTO UL3D SCSI w/ Atlas 10k RPM, USB Fastlane, DP 4.6.1, Various Plugz, Reason 2.5 etc.
jcar
Apogee X-Firewire with DP is fine
Post by jcar »
I have been using Apogee X-Firewire with DP 4.6 and my Rosetta 200 and it is working great.
G5 Dual 1.8, (NO AMD's, NO PCI-X) OS 10.42, 120 GIG 7200 RPM SATA Audio Drive, 2 X 250 Gig EZQUEST A/V Firewire drives, DP 4.6, Apogee Rosetta 200 w/Firewire card, MOTU 828MK11, UA LA-610, UAD-1 X 2, BFD Drums, Mach5, Battery2,Wife, Dogs X 2, and a little house out in the country!
bradswan
Post by bradswan »
I'm using the rosetta 800 with x-firewire into DP. The only way it works for me is to run at low priority, otherwise i get unbearable crackling. So it's working for me--I'm somewhat concerned that i am losing CPU?
Good luck
qo
Post by qo »
bradswan wrote:I'm using the rosetta 800 with x-firewire into DP. The only way it works for me is to run at low priority, otherwise i get unbearable crackling.
I had the same problem with the AD/DA-16X. Audio/MIDI Setup Aggregate Devices solved it for me (assuming you're using Tiger). Even if you have one device, it seems to work and allows for much more flexibility in Priority settings.
dwood
Post by dwood »
jcar, I'm thinkin of the 200. What priority setting do you use in DP and what sample rate are you working in?
Thanks.
Splinter
Post by Splinter »
This is an OT question, but does the Rosetta 200 allow you to use it as an A-to-D and D-to-A simultaneously? It seems somewhat useless to me if you can't.
zerosin
Post by zerosin »
As soon as they make my MiniMe FireWire capable. Youre so lucky to get more than 48/24. 8)
Splinter
Post by Splinter »
Splinter wrote:This is an OT question, but does the Rosetta 200 allow you to use it as an A-to-D and D-to-A simultaneously? It seems somewhat useless to me if you can't.
Anyone?
jcar
Post by jcar »
To answer Splinter, yes the Rosetta 200 is AD-DA at the same time.
dwood, I use low priority, buffer 512, host buffer multiplier x1, and record at 4800/24.
I was using the 828mkll as an interface but am now using it mostly as a doorstop since I got the Roesetta 200. I layer acoustic/electric guitars, bass, and vocals one at at time so it works for me that way. I only use the 828 when I have a drummer come in and play a drum Kat and I record his samples and MIDI. I will run the snare and kick through the rosetta and the other drums through the 828.
I mix ITB so all I need is the Rosetta and it works great for me.
Dor
Post by Dor »
yeah i'm using the rosetta 200 with a coleman controller for volume knob ... i use the 828 to monitor my synths and drum machines. That's about it these days.
Splinter
Post by Splinter »
jcar wrote:To answer Splinter, yes the Rosetta 200 is AD-DA at the same time.
Thanks for the response. I couldn't tell from Apogee's info if I could use it as my main D/A while recording through it for an A/D. This makes this device much more appealing. I'd also use it as a master clock. I can't envision getting the FW card for it though and would probably connect it via lightpipe to my 2408III, which, with my Digimax, gives me 18 inputs. Much more than I usually need.
So how does it sound? Is it up there with the AD-16X and Rosetta 800?
davedempsey
Post by davedempsey »
Splinter,
I use the Rosetta 200 as main in and out via s/pdif with my 828Mk2 - the sound quality is superb. The extra facilities offered by the Coda Audio Finishing Module make this piece great value. I've not looked at the X card option at this time.
Dave
Lots of stuff and a recently acquired ability to stop buying
signit
Post by signit »
I use a roseta800 with the x-firewire card and it works great, no problems on 10.4.2.
