Best Plugins? TC powercore firewire?
wonder
Re: Best Plugins? TC powercore firewire?
Post by wonder »
off hand, whats the price difference between the UAD and PCore Fwire?
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
wonder
Post by wonder »
ok.
so...
Waves vs UAD?
Who wins?
chrispick
Post by chrispick »
Wonder --
I don't know if this'll help you or confuse you, but here are two variables to weigh in your decision:
1. Do you want EQs and compressors that will color your sound as you use them? Or do you want these tools to be as transparent as possible?
2. Do you have any needs for additional plugs that come with these packages? For example, if you'd like a decent amp sim or modulation effects or channel strip ability with your EQ/compressor/reverb pack, then that can influence your purchase.
In short, I'm trying to put your mix needs before the disparate opinions of others because all of the mentioned plugs do the same thing, generally speaking, but do it differently . And some ship with different side orders, if you will, which might appeal to you.
To give you a personal example: I like different compressors for different uses (and I'm by no means a connoisseur). For me, color-adding comps like VintageBurner can sound great on drums, bass guitar and organs, but transparent comps like TrackPlug are more suitable for guitars and horns.
Dig what I'm saying?
wonder
Post by wonder »
i dig.....
mostly im looking for
1. a KILLER comp/limiter for vocals, drums, bass.
2. AWESOME reverb for vocals, drums
I do 90% acoustic instrument stuff (neo soul, r&b). SOME stuff with RMX drums and stuff....I dont do techno or rock so maybe that will help in helping me....?
bralston
Post by bralston »
The following UAD-1 plugs will make you smile big time. :D
LA-2A compressor (Great for vocals, anything really)
Fairchild Compressor (Great for drums & bass, very characteristic sound)
Precision Limiter (Awesome transparent limiter for mastering mixes)
Plate 140 (just like using the real thing...awesome plate 140 sound, great for vocals and guitar, drums, etc..)
<small>[ May 20, 2005, 10:57 PM: Message edited by: Brian W. Ralston ]</small>
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
chrispick
Post by chrispick »
i dig.....
Okay. My two cents then...
Given the neo soul / R&B tip, I'd suggest the UAD-1 for EQ/comp stuff because it emulates the warmth of vintage gear. I take it you probably want "warmth" or "fatness" over, say, "shimmer" or "gleen," at least if you have to pick one over the other.
And, if you can afford it, get the UltraPak for the Plate verb (or pick it up a la carte later).
Oh, and if you want that "real room" verb sound, the best plug-in bet is probably Altiverb.
<small>[ May 20, 2005, 11:15 PM: Message edited by: chrispick ]</small>
dixiechicken
Post by dixiechicken »
Wavearts at http://www.wavearts.com/ makes a couple
of very nice plugins.
1: They sound good
2: They are reasonably priced
4: The cpu-drain is very low
5: You can download and try them out for 30-days
6: They are fairly easy to use.
Quite a few professionals actually use them -
including me of course. ;)
Cheers: Dixiechicken
My God it's full of stars....
Mac Pro 6-Core Intel Nehalem/Xeon 2.93 GHz 32-GB ram, OS-X 10.13.5-Swe, DP-9.52, Unisyn-2.11, 828-MkII,MTP-AV usb, Latest drvs, Wavearts plugs, Kurzweil-2000, Proteus-2000, EPS-16, Pod-II,
Digitech RP-155, Soundcraft UI-16, Emes Kobalt monitors.
el gennaro
Post by el gennaro »
Wave plugins are great.
....expensive.http://www.unicornation.com/ubb/icons/icon14.gif
wonder
Post by wonder »
if i do the project pak....is it easy to upgrade to the ultra pak? or is it the same price as buying it new?
jackorhythm
Post by jackorhythm »
try the urs demos.
bralston
Post by bralston »
It is much more expensive to upgrade a Project Pak to have the same plugs as the Ultra Pak.
Project pack is $399 at jrrshop.com
Add all the plugs seperately to make it the equivalent of an Ultra Pak will cost you an additional $1380.
The Ultra Pak is $1199.95 right from the start. And it gives you all the plugs available right now...except the new Roland ones coming out in the next update.
The project Pak is really designed for users to cheaply add additional DSP cards to their system, as you can add up to 4 cards in one computer which will work in tandem on all the plugs you have authorized.
The Ultra Pak is really the way to go when buying into the UAD-1 for the first time.
Regards,
Brian Ralston
chrispick
Post by chrispick »
Or the Studio Pak for around $900 or so. Doesn't have the Plate or Pultec Pro, but still has the 1176, Fairchild and LA2A (as well as a few other goodies). Might be all you need.
donreynolds
Post by donreynolds »
I have been happy with the waves native gold and the DP plugs
Mac Studio M2 OS 15.3 Sequioa, Presonus Faderport 8, 150gig Raptor x 2, Glyph 2Tb drive DP 11.33, Antelope Discrete 8, BLA microclock ll, Presonus Central Station, Waves Plat. V7 , Slate Everything, Melodyne studio, SSD 5, TruePianos, Event 20/20 bas, Adam A7, Avantone Active MixCube, and other toys, Lotsa guitars, HeadRush GTR processor and a Korg Triton)
Watersound
Post by Watersound »
First of all, I'm using a daul 2Ghz G5 and Powercore kills my processor...that is BS that it takes the load off. Also, be wary, their customer support is bad...I had a painful experience with them and will never give them another penny. Go with Waves!!
wonder
Post by wonder »
at this point...its waves vs. uad to get my dollar.
I'm leaning towards UAD for the LA2A and 1176
