Can't monitor effects in Real-Time
princezulu
Post by princezulu »
Hi all,
I'm using DP 7.2 and an Apogee Duet into a Macbook Pro. My issue is that I cannot seem to record guitar tracks while hearing the effect plug-in I have chosen. I can hear the guitar signal just fine, but not the effect. I have selected 'monitor through effects' and the option direct hardware playthrough is eternally greyed out and isn't an option to select.
Could some who uses the same set up perhaps respond with their configuration for me to copy? I'm not sure if I issue is in DP or the Duet?
Thanks so much.
kassonica
Re: Can't monitor effects in Real-Time
Post by kassonica »
Reading the getting started guide that came with DP would very useful.
princezulu
You don't think I've done that?
I've been a DP user since version 2.6 and I've never had this issue before. I've just switched from an 828 MK II to the Duet - and onto 7.2, so I'm lost as to what the issue is. I've always been able to record and monitor effects at the same time before.
No amount of 'RTFM' has been able to throw light on it.
Thanks.
princezulu
Figured out I had to use Maestro Mixer - from software setting.
kassonica
Post by kassonica »
princezulu wrote:You don't think I've done that?
Thanks.
from version 2.6 and you just found motunation now.....
Well if thats the case welcome.
In fairness, I only recently changed the forum settings to allow it to be indexed by Google. :)
kassonica
Post by kassonica »
James Steele wrote:In fairness, I only recently changed the forum settings to allow it to be indexed by Google. :)
Yes I know :D Hence why I've added the welcome.
I get a bit protective about DP sometimes... Didn't mean to upset the poster.
