Bundles mess
Killahurts
Re: Bundles mess
Post by Killahurts »
Gabe S. wrote:Ultimately, I think it's reasonable for users to ask for a fix from MOTU regarding this issue. This problem can kill a mix very easily if you didn't realize a Bundle assignment disappeared. And it creates unnecessary question marks every time you open a session.
Hey Gabe, I hear you. I'm really worn out with this problem and sadly enough, I've gotten USED to it. Part of my workflow has become going in and resetting the damn bundles most every time I open a project. I'm going to submit another email to MOTU so we can make the chorus bigger.. you're right, if enough of us complain, they'll make it a top priority.
I think a lot of the techs at MOTU simply don't create templates as massive as some of us do, and so even if they run across a problem like this, it's a minor inconvenience for them.
Oh and Gabe, thanks for all the hard work rebuilding your giant template- we have indeed one more piece of the puzzle and there appears to be somewhat of a workaround with the "stationary" trick. But still, MOTU needs to understand that this is a serious problem. If I know they get it, I'll be glad to be patient and wait for a fix.
Sorry for :deadhorse:
Copy text, then submit.
bolla
Re: Bundles mess
Post by bolla »
I have a large project that I have been reconstructing due to computer and VEP upgrade.
It is now loading the Kontakt and VEP extra outs OK.
I deleted any unused bundles. Perhaps this helped. All limbs are now crossed whenever I start the computers.
If I make a template from it however, those extra bundles get corrupted.
I've tried loading in the bundles from my "good" project but they also get corrupted.
So I am now, as a workaround, loading my good project and then saving a copy of it when I start a new track. Actually I save about ten and stockpile them.
Can I encourage everyone to report the problem to MOTU
8 Core 2.8 10.11.1 DP 8.07 | Dual 2.5 G5 VEP Slave | PC i7 920 VEP Slave | UAD Sat Quad | MiniMoog
hrw
Re: Bundles mess
Post by hrw »
nickysnd wrote:Every time I open up a project I find my bundles messed up. I fix them, I reassign the instruments' ins and outs, but then when I open the project next time the bundles are all messed up again. And again. Every time I have to reassign the inputs and the outputs. Never had this problem in DP5.
Basically what happens is, the ins/out assignments disappear, or get assigned to some other ins and outs. Worse, some bundles don't even hold together in pairs. For example, when I want to (re)assign the New Bundle Kontakt 3-4, I see that the Kontakt bundles begin with 4-5, which is absurd. Then when I check the Instruments in the Bundles, the Kontakt 3 out (which previously was the L in the L-R pair called Kontakt 3-4) was bumped at the end of the list. Similar happens with the Stylus bundles pairs, also Omnisphere's. Something is deeply wrong here. Hope what I'm saying makes sense. Is there a way to set the bundles right once and for all?
Any suggestion will be appreciated.
+1 with VE Pro and Kontakt!
Hope this gets fixed it is becoming increasingly annoying and slowing down my workflow to constantly have to re adjust them.
Please MOTU, fixy uppy.
haydn.
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
delcosmos
Re: Bundles mess
Post by delcosmos »
Please MOTU FIX this, I have to Re-Assign my Kontakt Aux outputs every time I open a song, and as someone mentioned above, if you forgot to do this, you could mix a song without notice that maybe one synth or drum is off!!
PLEASE MOTU, its time to fix this.
Best regards.
delcosmos.
8.07 64bit, Spire, Nexus, Fab FilterDiva, Gladiator, Nexus, Sylenth, Stylus RMX, Live 9, Reason 6.5, Komplete 8, AD Keys, AD Drums, Geist, Ivory, Waves 9 Mercury, Sound Toys, Fab, VEPro, Reason, Live, UAD2, x3 2408mk3, PCI424, MAC PRO Dual 3.46 Ghz 12 core Intel Xeon, Memory: 64gb ram, MAC OS X: 10.8.6
Tim
Re: Bundles mess
Post by Tim »
Or how 'bout:
Please, MOTU... value your loyal customers enough to acknowledge that you are aware that this problem exists, and that you might just care enough to look into fixing it.
We can handle a little dialog here: we're not f'ing idiots!
bdr
Re: Bundles mess
Post by bdr »
Please everyone that is reporting this make sure to put in a tech support request to MOTU. Although we know that Magic Dave posts here frequently and probably others from MOTU check in here now and then, I don't believe I've ever seen an actual public acknowledgment of a bug on this board (naturally I stand to be corrected). So don't just rely on venting on MOTUnation for it to be looked at by MOTU.
Mac 2.8 8-core, 20 GB RAM, Mac 10.9, DP 8, EWQLSO Platinum Play, Mach V II, Kontakt 5, Superior Drummer, AIR, Absynth 5, Plectrum, CronoX, Albino3, RMV, cup of tea.
delcosmos
Re: Bundles mess
Post by delcosmos »
I already sent a tech note to MOTU about this long time ago, since version 7 and never got a response.
I really hope they fix this in the next update because I feel so frustrated everytime I open a song and have to re-set all my VI bundles. :banghead:
sinkd
Re: Bundles mess
Post by sinkd »
Just added a tech link. I'm really getting disgusted that this has not been fixed or even acknowledged.
DS
hrw
Re: Bundles mess
Post by hrw »
http://www.motunation.com/forum/viewtop ... =1&t=43680" onclick="window.open(this.href);return false;
DAW:DP8.05
VI's/Plug-ins:
million others.
Killahurts
Re: Bundles mess
Yep, but I gotcha beat:
http://www.motunation.com/forum/viewtop ... =1&t=40360" onclick="window.open(this.href);return false;
This is when I first discovered it.
hrw
Re: Bundles mess
Post by hrw »
Haha.
Snap!
DAW:DP8.05
VI's/Plug-ins:
million others.
delcosmos
Re: Bundles mess
Post by delcosmos »
I'm confident that MOTU will fix this in next update. They've been releasing updates very often, hope this will be fixed in the next one.
Best.
delcosmos.
Killahurts
Re: Bundles mess
delcosmos wrote:I'm confident that MOTU will fix this in next update. They've been releasing updates very often, hope this will be fixed in the next one.
Best.
delcosmos.
I think they will too. When you think about it, Bundles is a GREAT feature, in and of itself. They certainly want it to work reliably.
Re: Bundles mess
Killahurts wrote:When you think about it, Bundles is a GREAT feature, in and of itself. They certainly want it to work reliably.
A great feature? That's putting it lightly. Bundles is a mechanism to link objects in an application to the external world, and this is one of the most basic and essential features of any program, going back IBM JCL DD cards 50 years ago.
Killahurts
Re: Bundles mess
Well OK. I guess I just like the way it's implemented in DP.
