Uvix isn't importing Intakt format?
sdfalk
Post by sdfalk »
I've had no ther problems with any other format, just from Intakt.
UV seem to recognize That they are there, but can't "see" the
samples.
No keymaps, nuthin.
Any suggestions?
A Metric Halo ULN8-3D…mmmmmmm
sdfalk
Re: Uvix isn't importing Intakt format?
Post by sdfalk »
..anyone?
BKK-OZ
Post by BKK-OZ »
not quite certain of what you mean...
do you mean that when you fire up UVI and navigate to the folder/disk with Intakt samples, they don't appear in the browser?
-you have clicked on the '.nki' tab in UVI, right?
give a little more info and we'll see if we can figure this out.
Cheers,
BK
- M Kaku
sdfalk
Post by sdfalk »
Yes I guess I didn't explain that to well.
I have clicked on the nki tab, navigated to the samples, and what
shows up is the names of the samples but when I select the
sample itself (drumloop 1 for example) nothing shows up
in the key map zone or the sample display..empty.
So when i try to save them as MachFIve samples I just get
nothing.
Is that a bit better? :)
Akai96
Post by Akai96 »
I have the same issue with Intakt.
PLEASE HELP!! :eek:
Just testing this thing out
BKK-OZ
Post by BKK-OZ »
I am not familiar with Intakt from my own use, other than Altered States, but it could be that the format is locked. I have Altered States (which uses the Intakt engine) and I know that I can't import those into M5.
Maybe you should have a quick look on NI's site to confirm, but I think that might be the problem.
Does it make any difference which Intakt library you try to access?
Cheers,
BK
Cheers,
BK
- M Kaku
Dfab020
Post by Dfab020 »
Hello
Hmmm .. you have gotten me curious. I am going to try and do this later and let you know what happens ..
--Bryan--
http://www.dfabstudios.com/" onclick="window.open(this.href);return false;
http://www.dfabmusic.com/" onclick="window.open(this.href);return false;
sdfalk
Post by sdfalk »
I took a run at the Ni site and sisn't find any info about the Intakt
format being locked or not.
If anyone else finds anything please post.
sdfalk
Post by sdfalk »
Nothing?
fontane
Post by fontane »
i cant import kontakt 2 files :(
Shane Fontane
www.shanefontane.com
Dual 1.8 G5 | 2.5GB | OS X 10.3.9 | DP 4.52 | UAD | Mach 5 | SampleTank 2 | Kontakt 2 | MX4 | Recycle | MAudio Firewire Audiophile | Undying Passion For Music
BKK-OZ
Post by BKK-OZ »
well, I had a look on NI's site and couldn't find anything out about the copy protection, but I think that might be the issue you are dealing with.
I would suggest e-mailing NI to ask them what the deal is, that way you should get a definative answer. I didn't trawl thru their forums, but that might be a source too.
Don't forget kvr.com - they have pretty active forums there too.
Sorry I couldn't be of more assistance.
Cheers,
BK
Cheers,
BK
- M Kaku
vic_france
Post by vic_france »
The "Powered by N.I." monolithic files, such as Intakt, Kompakt etc. are all closed formats.. so this has nothing to do with MachFive.
Mac MDD dual 1GB/1.25GB RAM/160GB internal disc/MOTU PCI-424/2408 MK3/MTP AV
MAC OS X 10.3.8/ Digital Performer 4.52/Cubase SX 3.02
MAC OS 9.2.2/Digital Performer 3.11/ Cubase VST_32/5.2pb
sdfalk
Post by sdfalk »
Yes I know.
I'm talking about the application that comes with MachFive UVI Extract.
It appears it has a facility to translate
NI products like INtakt but only worked partially.
That was my point
