Uvix isn't importing Intakt format?
- sdfalk
I've had no ther problems with any other format, just from Intakt.
UV seem to recognize That they are there, but can't "see" the
samples.
No keymaps, nuthin.
Any suggestions?
samples.
No keymaps, nuthin.
Any suggestions?
A Metric Halo ULN8-3D…mmmmmmm
- sdfalk
Re: Uvix isn't importing Intakt format?
..anyone?
- BKK-OZ
not quite certain of what you mean...
do you mean that when you fire up UVI and navigate to the folder/disk with Intakt samples, they don't appear in the browser?
-you have clicked on the '.nki' tab in UVI, right?
give a little more info and we'll see if we can figure this out.
Cheers,
BK
- M Kaku
BK
- M Kaku
- sdfalk
Yes I guess I didn't explain that to well.
I have clicked on the nki tab, navigated to the samples, and what
shows up is the names of the samples but when I select the
sample itself (drumloop 1 for example) nothing shows up
in the key map zone or the sample display..empty.
So when i try to save them as MachFIve samples I just get
nothing.
Is that a bit better?
nothing.
I have the same issue with Intakt.
PLEASE HELP!!
PLEASE HELP!!
Just testing this thing out
- BKK-OZ
I am not familiar with Intakt from my own use, other than Altered States, but it could be that the format is locked. I have Altered States (which uses the Intakt engine) and I know that I can't import those into M5.
Maybe you should have a quick look on NI's site to confirm, but I think that might be the problem.
Does it make any difference which Intakt library you try to access?
Cheers,
BK
Cheers,
BK
Cheers,
BK
- M Kaku
BK
- M Kaku
Hello
Hmmm .. you have gotten me curious. I am going to try and do this later and let you know what happens ..
--Bryan--
--Bryan--
http://www.dfabstudios.com/" onclick="window.open(this.href);return false;
http://www.dfabmusic.com/" onclick="window.open(this.href);return false;
- sdfalk
I took a run at the Ni site and sisn't find any info about the Intakt
format being locked or not.
If anyone else finds anything please post.
- sdfalk
Nothing?
i cant import kontakt 2 files
Shane Fontane
www.shanefontane.com
Dual 1.8 G5 | 2.5GB | OS X 10.3.9 | DP 4.52 | UAD | Mach 5 | SampleTank 2 | Kontakt 2 | MX4 | Recycle | MAudio Firewire Audiophile | Undying Passion For Music
- BKK-OZ
well, I had a look on NI's site and couldn't find anything out about the copy protection, but I think that might be the issue you are dealing with.
I would suggest e-mailing NI to ask them what the deal is, that way you should get a definative answer. I didn't trawl thru their forums, but that might be a source too.
Don't forget kvr.com - they have pretty active forums there too.
Sorry I couldn't be of more assistance.
Cheers,
BK
Cheers,
BK
Cheers,
BK
- M Kaku
BK
- M Kaku
The "Powered by N.I." monolithic files, such as Intakt, Kompakt etc. are all closed formats.. so this has nothing to do with MachFive.
Mac MDD dual 1GB/1.25GB RAM/160GB internal disc/MOTU PCI-424/2408 MK3/MTP AV
MAC OS X 10.3.8/ Digital Performer 4.52/Cubase SX 3.02
MAC OS 9.2.2/Digital Performer 3.11/ Cubase VST_32/5.2pb
- sdfalk
Yes I know.
I'm talking about the application that comes with MachFive UVI Extract.
It appears it has a facility to translate
NI products like INtakt but only worked partially.
That was my point
That was my point
