dewdman42 wrote:I only have one request. Would be great if MOTU provided some machine-farm capabailities, ie, audio and MIDI networking between multiple macs, hosting plugins on other machines to get more cpu power, etc..
+1 +1 +1 +1 +1 +1 +1
It might save time, unless you just wanted to quickly open a project to see what it was and discovered you have to sit through the change in buffer and then have MAS restart and all your plugs reload. Could sort of cost time in some situations too.gavspen wrote:Waaaaay to long a thread to read it all, so apologies if I'm being redundant, but......
I know some have mentioned having the buffer setting displayed. In addition, couldnt it be saved with each project? Sometimes, if I close one job where I've been working with a low buffer (say, doing vocals) and then open another one where I need a high buffer (to mix), it opens up, then I have to go to "Hardware settings" and.....well, you all know.
It's not a biggie, I confess, but it would save a little time. You know, like those keyboard commands?.....
Gavin
Plus anothergrouse wrote:Agreed +1.Tesionman wrote:Agreed!chaim wrote: • my long time request, a solo button in the SE, by each track.
I'm not sure what you mean James, since you have to sit through the MAS restart and plugs reload every time you open a different project, dont you? But if you open it up, and only then realise you need to change the buffer, you have to sit through it twice, no?James Steele wrote: It might save time, unless you just wanted to quickly open a project to see what it was and discovered you have to sit through the change in buffer and then have MAS restart and all your plugs reload. Could sort of cost time in some situations too.
There's your lyrics right there!blazingrythm wrote:
It's my birthday today and I'm pretty buzzed.
So forgive me for posting such dumb posts.
I think my breath would probably melt such device a device at this point.
I'm amazed I can still type...
Love this forum!
Happy Birthday to me!
In my case, not even MOTU could help me with that...blazingrythm wrote: Another would be to alert me when my wife is on her way home from work so I can turn the volume down in order not to hear her complain.
Bidule does this with DP right now.Timeline wrote: Parallel running MIDI/VI input software which runs outside DP but attached to the input switching and record control of DP automation allowing MIDI instruments to be heard/monitored in real time with little latency without changing buffers to 256 or lower which can crash the DP app on large sessions. Multi processors now make this doable. MOTU would need to leave one processor open for such a system but large buffers on playback would not effect input latency ever again.
I knew I had breezed over this before without checking it out, but that works perfectly! Thank you.bdr wrote:benmrx wrote: 22) I belive they might have had this in older versions, but a "quick filter" button in the sequence editor.
There is an assignable command
'toggle show active layer only' that works in the SE
is this what you're looking for?
